SanDisk - Flash memory card - 32 GB - Class 4 - microSDHC
Quicklinx: 7ZZ0WS00 Mfr#: SDSDQM-032G-B35
Type: microSDHC
Capacity: 32GB
SD Speed Class: Class 4
Stock Status: Clearance
Hurry, only 3 left in stock!
£10.00 ex VAT
£12.00 inc VAT
Get Dependable Storage for More Music, Photos, and Videos on Your microSD/microSDHC Enabled Device
32GB The SanDisk microSD and microSDHC memory cards offer an easy, affordable way to expand your mobile device's onboard memory. Available in capacities up to 32GB, these cards give you additional storage space for your favorite photos, and videos.
  • Available in capacities up to 32GB**1 gigabyte (GB)=1 billion bytes. Some capacity not available for data storage.
  • Adds storage to microSD/microSDHC enabled devices
  • Records more video on the go - even in HD**HD (1280x720x30fps) video support may vary based upon host device, file size, resolution, compression, bit rate, content and other factors.
  • Shock proof**Shock and vibration proof: Capable of withstanding up to 500Gs of shock., x-ray proof**X-ray proof: Immune to airport X-rays, temperature proof**Temperature proof: Capable of withstanding operating temperatures from -13ºF to 185ºF (-25ºC to 85 ºC). , and waterproof**Water proof: Tested to withstand up to 72 hours in 1m salt or fresh water; IEC 529 IPX7; product must be clean and dry before use.
Expand Your Mobile Device's Storage
These memory cards instantly add storage space to any device with a microSD/microSDHC memory card slot. Expanding the memory of your smartphone or tablet means you can capture more photos and video, carry more files, and enjoy your favorite music wherever you go.
Record HD Video with your Mobile Phone
These cards are completely compatible with mobile phones, laptops, tablets and other devices that support the microSDHC format and are capable of recording hours of HD video (720p).
Durable Design
Designed to withstand the toughest conditions, SanDisk microSD and microSDHC Memory Cards are waterproof, shockproof, and X-ray proof. They can operate in temperatures ranging from -13 to 185 degrees Fahrenheit, so you can enjoy mobile media in almost any climate. Even if your device doesn't survive, your SanDisk memory card will.
Warranty
The SanDisk microSD/microSDHC Memory Card is backed by a five-year limited warranty.
  • The capacity you need to store more
    Smartphones and tablets can do so much these days that unless you have enough capacity you could be missing out on their capabilities. 32GB SanDisk microSDHC memory cards give you plenty headroom for whatever you need to store, just in case – even if you want to carry hundreds of family photos, hours of videos or a comprehensive selection of your favourite music tracks around with you.
  • Make more of your time out
    SanDisk microSDHC memory cards help store your photos, videos, music and more, so that it is easy for you to share your experiences, memorable moments and favourite tunes with your family and friends.
  • Make more of your work
    Wherever you are, 32GB SanDisk microSDHC memory cards help keep your work to hand so that you can carry on with presentations, spreadsheets and documents at a moment's notice, then share them with colleagues.
  • Keep on using your card anywhere
    SanDisk microSDHC memory cards are designed to be waterproof, temperature-proof, shock-proof and x-ray-proof, so they will keep on working whatever life throws at them.
  • Compatibility
    The 32GB SanDisk microSDHC memory card works with any device that has a microSD card slot.
  • Reassurance with performance
    SanDisk develops and engineers its microSDHC memory cards to maximise reliability, so you can count on your 32GB microSDHC memory card to store your important files.You can live life with total peace of mind. The 32GB SanDisk microSDHC memory cards are backed by a 5-year limited warranty.
SanDisk - flash memory card - 32 GB - microSDHC
Flash memory card
microSDHC
Storage Capacity
32 GB
Speed Rating
Class 4
Enclosure Colour
EMEA
5-year warranty
Flash memory card
Storage Capacity
32 GB
Enclosure Colour
Compatibility
Non-specific
EMEA
SD Speed Class
Class 4
microSDHC
Limited warranty - 5 years
11 mm
15 mm
Thickness
1 mm
0.4 g
Type: microSDHC
Capacity: 32GB
Brand: Sandisk
Price Range Ex VAT: 0 - 50
