RJ45 UTP patch network cable is used to connect a computer to a broadband modem/LAN/switch etc. Can also be used between switches and in distributor boxes. The CAT6 standard is an improved version of CAT5e, specially designed to support 1000 Mbit/s Ethernet with an optimal transfer rate and minimal data packet loss. The cable also supports 10 and 100 Mbit/s Ethernet, which enables the speed to be optimized.
- Sandberg network cable - 2 m
- Network cable - CAT 6
- Technology
- Length
- 2 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Network Cable Type
- Technology
- Length
- 2 m
- Connector
- RJ-45 - male
- RJ-45 - male
