Samsung Xpress M2885FW Mono Laser Multifunction Printer
Quicklinx: B2YLWS00 Mfr#: SL-M2885FW/SEE
No more waiting. Samsung's high-performance Xpress M2885FW multi-function printer delivers great results while cutting costs. Print wirelessly and share effortlessly with the Samsung Xpress M2885FW. All it takes is a simple tap with its advanced NFC technology, and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features. Simply tap your NFC-enabled mobile device to the Samsung Xpress M2885FW to quickly and easily establish a Wi-Fi direct connection, so you can print virtually any content from your smartphone or tablet.
  • Powerful, affordable and simple to use
  • Makes your smartphone even smarter
  • Get print on tap
  • Scan
    Scan images and send them directly to your mobile device.
  • Fax
    Share the content on your mobile device instantly via fax.
  • Print wirelessly with mobile print app
    Release the full productivity of your mobile devices with the Samsung Mobile Print App, available for iPhone, iPad, Android, and Windows Phone devices. You can easily print directly from your mobile device to the printer over your wireless network. Unlock your full potential with a mobile solution that allows you to print images, PDFs, and the full suite of Microsoft Office documents, including Word, PowerPoint, and Excel. You can work smarter and faster by harnessing the power of advanced Samsung connectivity.
  • Print anywhere with Google Cloud Print
    Google Cloud Print works on Smartphone, Tablet PC, Google Chromebooks, PC/Notebooks and other Web connected devices. Once enabled, you can print from anywhere in world with an internet connection.
  • No need to call for service
    Confusing error messages are a thing of the past. Just tap your NFC-enabled smartphone to the printer and you'll be guided through a step by step series of troubleshooting images or videos so you can get to work faster.
  • Print fast, don't wait
    However demanding your professional printing needs, the Samsung Xpress M2885FW delivers great results - fast. Save time by printing complex documents at speeds of up to 29 pages per minute (PPM) thanks to a powerful 600MHz processor and 128MB of memory. 4-in-1 office functionality allows you to scan, copy, and fax in addition to print.
  • Give a good impression
    Now impressive professional-quality prints are possible for everyone. Your Samsung Xpress M2885FW Series delivers sharp, clear prints that are sure to make a big impact. Thanks to its 4800 x 600 dpi effective resolution and Rendering Engine for Clean Page (ReCP) technology, you can enjoy higher performance and quality without the need for a bulky larger printer. What's more, quality-boosting features give you more detail, smoother images and clearer text.
  • High resolution printing
    Even complex images and small text are delivered in fine, detailed prints, thanks to high-resolution print quality up to 4800 x 600 dpi effective.
  • Edge enhancement
    Enjoy clearer text and more vivid images thanks to automatic edge enhancement.
  • Great copying and colorful scanning
    With your Samsung Xpress M2885FW Series, superior-quality copies and scans are now a reality. Great performance means fine text and images are sharper, delivering much more legible text and vibrant, smooth images.
  • Enhance fine lines and small text
    Unlike some others, the Samsung Xpress M2885FW ensures thin lines and small text are captured when scanning or copying. ReCP technology maximizes the amount of text that is captured, delivering higher-quality prints and scans.
  • No more halftone patterns
    With a Samsung Xpress M2885FW Series, you can remove halftone patterns on images and enjoy the clear and smooth images you need for truly professional print results.
  • Print with more paper types
    Whatever you need to print, your Samsung Xpress M2885FW Series can handle it. The small but robust printer can use a range of media up to 59 lb. stock, including paper, labels, cards, envelopes and overhead projector (OHP) transparencies. You can easily select the paper type you need from the multipurpose (MP) tray, so it's convenient as well as flexible.
  • One-touch Eco button delivers savings
    Cut your toner and paper costs with the One-Touch Eco Button. It's optimized, so just a click of the button allows you to easily use N-up and duplex printing, which lets you print multiple document pages on a single sheet and skip wasteful blank pages. With toner save mode, you can also reduce toner use and bring costs down even more.
Samsung Xpress M2885FW - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
12000 impressions
Max Copying Speed
Up to 28 ppm
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Up to 4800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
142 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, thin paper, thick paper, cotton paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Scan to folder
40.1 cm x 36.2 cm x 36.7 cm
11.3 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
12000 impressions
Display
2 lines
Scan to folder
Standard Memory
128 MB
Copying
Max Copying Speed
Up to 28 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 28 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, SPL
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 600 pages
Fax Machine Features
Fax forwarding, automatic redialing, last number redial, multi-send, delayed sending
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
120 sheets
ADF - 40 sheets size: 142 x 148 mm - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 120 sheets
Speed Details
Printing: up to 28 ppm (A4) - B/W , Printing: up to 29 ppm (Letter A) - B/W , Copying: up to 28 ppm (A4) - B/W , Copying: up to 29 ppm (Letter A) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.9
400 Watt
Power Consumption Standby
50 Watt
First Copy Out Time B/W
14 sec
Consumables Included
1 x toner cartridge (black) - up to 1200 pages
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
40.1 cm
36.2 cm
36.7 cm
11.3 kg
Sound Emission
26 dBA (idle) / 53 dBA (operating)
