Print wirelessly and share effortlessly with the Samsung Xpress C1810W. All it takes is a simple tap of the advanced NFC technology, and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features. Simply tap your mobile device to the Samsung Xpress C1810W to print virtually any content.
Whatever size your team, and however busy you are, you can rely on the C1810W to constantly deliver professional, quality color output. Because anything less isn't good enough. Accelerating your business' productivity begins with your printer. With its 19/19 pages per minute output and a first page out time as low as 16 seconds the C1810W delivers where it counts.
Makes your smartphone even smarter
Print wirelessly and share effortlessly with the Samsung Xpress C1810W. All it takes is a simple tap of the advanced NFC technology, and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features. -
Get print on tap
Simply tap your mobile device to the Samsung Xpress C1810W to print virtually any content. -
Print anywhere with Google Cloud Print
Effortless mobile printing with impressive compatibility, optimized for any task or occasion. Google Cloud Print works on smartphones, tablet PCs, Google Chromebooks, PCs and other web connected devices. -
Simple registration to Google Cloud
Google Cloud Print allows you to connect and print from wherever you are. Just tap your smartphone to the printer and automatically connect it to the cloud - no login necessary. -
No need to call for service
Confusing error messages are a thing of the past. Just tap your NFC-enabled smartphone to the printer and you'll be guided through a step by step series of troubleshooting images or videos so you can get to work faster. -
Enjoy professional color output
Whatever size your team, and however busy you are, you can rely on the C1810W to constantly deliver professional, quality color output. Because anything less isn't good enough. -
Make sharp images and text even sharper
Boost the overall quality and vividness of your output with unique ReCP (Rendering Engine for Clean Pages). It automatically adds dots along the edges of images and characters, meaning everything looks so much sharper and cleaner. What's more, those white gaps between colored areas that are so common with other devices are eliminated. What you and your team are left with is an outstanding color output. -
Make colors more vibrant
The advanced Polymerized Toner formulation has smaller and more uniform particles, giving lines extra definition, and color more impact. Its higher wax content not only improves mage gloss, but also enhances print durability by preventing unwanted fading. And as the polymer toner can be applied in a thinner layer with lower fusing temperatures, it reduces the paper curl and energy consumption as well. -
A higher level of printing performance
Accelerating your business' productivity begins with your printer. With its 19/19 pages per minute output and a first page out time as low as 16 seconds the C1810W delivers where it counts. -
More power, better productivity
With the power of two cores the device can process files simultaneously and the 256MB memory ensures large print jobs won't slow it down. -
USB direct
Print images and PDFs directly from a USB memory stick, which can be plugged in directly below the operating panel. -
Cost effective printing
Stay in control of your expenses. Lower costs per page and a more energy efficient printer means lower costs for you or your business. -
High yield, low costs
Higher yield cartridges means more time between changes, saving you time, while low toner costs means less cost for every page. You'll find the Total Cost of Ownership is slashed. -
Less power, less to pay
There is more money to be saved by reducing power consumption. The innovative polymerized toner requires a lower fusing temperature, resulting in less energy consumption. With a typical energy consumption (TEC) of only 1.3kWh (less than 1.52kWh with Wi-Fi Direct enabled) this printer saves you on money and reduces energy waste. -
Eco printing
One push of the Eco button lets you save on costs. Print multiple pages on one sheet, skip blank pages or print in grayscale. You can edit the defaults at any time to customize how you print and how much you save.
- Samsung Xpress C1810W - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 16.62 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 19 ppm - colour - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (Colour)
- 9600 x 600 dpi
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n)
- Processor
- 533 MHz
- RAM Installed (Max)
- 256 MB (512 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6C, SPL (Samsung Printer Language), PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper, glossy paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet paper cassette, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 40000 pages
- Networking
- Print server
- System Requirements
- UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.9
- 42 cm x 42.6 cm x 26.4 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 9600 x 600 dpi
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
- Media Handling
- Processor
- 533 MHz
RAM
- 256 MB / 512 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 98 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 40000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 700 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 700 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 700 pages ISO/IEC 19798
- Power Device
- Power supply - internal
- 380 Watt
- Power Consumption Stand by
- 50 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 50 dBA
- 42 cm
- 42.6 cm
- 26.4 cm
- 16.62 kg
