What's in the Box:
- Samsung Xcover B550 - Dark Silver (SM-B550H)
- Mains Charger
- Headphones
- User Manual
Display
Buy the rugged Samsung Xcover B550 from Handtec. It features a 2.4 inch screen with a simple resolution QVGA (240 x 320 pixels). The 2.4 inch screen is designed so that contacts, SMS and images are clearly visible to you.The Samsung Xcover B550 is perfect for making calls and sending SMS.
Design
Your Samsung Xcover B550 comes with a traditional keypad. It is specially designed for all those who do not want to use touch screen phones. Moreover, the keypad makes it more durable to be used in tough conditions.Moreover, an additional feature of your Samsung Xcover B550 is the IP67 rating. This makes the device water and dust proof. It can stay in one meter of water for up to 30 minutes. Samsung has dressed your Xcover B550 in a shell that with stands bumps and drops.
Camera
Your Samsung Xcover B550 comes with a 3 mega pixel camera making it useful for taking pictures while you are at a construction site. Moreover, bluetooth is included so that you can share these images with other devices.
Technical Specifications:
General:
- Network: GSM 850 / 900 / 1800 / 1900, HSDPA 900 / 2100, undefined
- Chipset: SC7703A
Multimedia:
- Camera: 3.15 MP, 2048 x 1536 pixels, LED flash
- Audio MP3-WAV-eAAC+ player
- Games: Downloadable
- Java: MIDP 2.0
- Headphone jack: 3.5 ??
- Playing video: MP4/H.263 player
- The front camera: No
Calls:
- Ringtones Type Vibration; Polyphonic, MP3
Communication:
- Interfaces, Bluetooth, NFC, USB
- Internet access: GPRS, EDGE
- Satellite navigation: GPS
Memory and processor:
- Supported memory cards: microSD 32 GB
- Memory card slot: Yes
- Built-in Memory: 128 MB
- RAM:128 MB
Display parameters:
- Screen Type TFT
- Diagonal Screen "2.4"
- Image Size240 x 320
- The number of pixels per inch (PPI):167
Battery:
- The type of battery used: Li-Ion
- Capacity of the battery used: 1300 mah
Multimedia:
- Camera Resolution (pixels): 2048 x 1536
- The flash: LED flash
Communication:
- Browser: WAP 2.0/xHTML
- Samsung Galaxy Xcover 550 - dark silver - 3G feature phone - GSM
- Product Type
- 3G feature phone
- Manufacturer Model Number
- SM-B550H
- Display
- LCD display - 320 x 240 pixels - 2.4" - TFT
- FM radio, LED flashlight
- Processor
- 460 MHz (dual-core)
- Memory
- RAM 128 MB
- Supported Memory Card
- microSDHC slot - up to 16 GB
- Main Camera
- 3.1 Megapixel focus: automatic
- Service Provider
- Not specified
- Form Factor
- Bar Rugged
- Wireless Interface
- Bluetooth
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack
- Talk Time
- Up to 480 minutes
- Protection
- Shockproof, waterproof
- Dark silver
- 56.2 mm x 13.95 mm x 129 mm
- 120.4 g
- Specific Absorption Rate (SAR)
- 0.78 W/kg (head) , 0.44 W/kg (body)
- SAR Category (Belgium)
- B
- Product Type
- Feature phone
- SM-B550H
- Form Factor
- Bar - Rugged
- Protection
- Integrated Components
- 56.2 mm
- 13.95 mm
- 129 mm
- 120.4 g
- Body Colour
- Dark silver
- B
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 3G
- Service Provider
- Not specified
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- Bluetooth 3.0
- Bluetooth Profiles
- FTP, HFP, HSP, OPP, A2DP, AVRCP
Media Player
- Supported Digital Audio Standards
- WAV, AAC, MP3, MIDI, M4A
- Supported Digital Video Standards
- MPEG-4, 3GP
- Clock Speed
- 460 MHz
- Processor Core Qty
- Dual-core
- RAM
- 128 MB
- Supported Flash Memory Cards
- microSDHC - up to 16 GB
Main Camera
- Sensor Resolution
- 3.1 Megapixel
- Focus Adjustment
- Automatic
- Light Source
- LED light
Display
- LCD display
- Technology
- TFT
- Diagonal Size
- 2.4"
- Display Resolution
- 320 x 240 pixels
- Colour Depth
- 262,144 colours
- Connector Type
- Headset jack - mini-phone 3.5mm , USB
- Capacity
- 1500 mAh
- Talk Time
- 480 minutes
- Run Time Details
- Talk (WCDMA): up to 480 min
- IP67
- Included Accessories
- Power adapter
