Samsung Xcover 4
Samsung Xcover 4
Quicklinx: D1ZNWS00 Mfr#: SM-G390FZKAXEU#BTBM
Operating system: Android
Model: Xcover 4
Screen Size: 5in
Rear Camera: 13 Megapixel
Mobile Connectivity: 4G
  • microSDHC
  • Android
Hurry, only 3 left in stock!
£169.00 ex VAT
£202.80 inc VAT
Rugged design with a sense of sophistication. At a slim 9.7mm wide, the Galaxy Xcover4 is thinner than previous generations and features an easy-to-grip, non-slip finish. It won’t slide out of your hand unexpectedly while on the go.
  • Fit for life on the move
    Rugged design with a sense of sophistication. The Galaxy Xcover4 is thinner than previous generations and features an easy-to-grip, non-slip finish. It won't slide out of your hand unexpectedly while on the go.
  • Reliably durable
    Designed to function wherever you go, with IP68 and MIL-STD 810G certification, the Galaxy Xcover4 is durable enough to withstand harsh conditions. Whether you're hiking or playing outdoor sports. You can rest assured your device is protected against dust and water.
  • Experience richer resolution
    Open your eyes to extraordinary color. The Galaxy Xcover4 display measures 5.0" to deliver exceptional detail. Discover an overall better viewing experience when streaming your favorite multimedia.
  • Shoot exceptional photos
    Higher resolution to create stunning stories. Whether you're taking selfies or capturing stunning landscapes its front 5MP and 13MP rear flash cameras will bring out the best of the world around you. Simply double click the home button for instant access and begin shooting.
  • Increased touch sensitivity
    Keep your hands warm and dry during use. The Galaxy Xcover4 features an intuitive display that lets you interact with your device even with gloves on so you can go on working outside or enjoying outdoor activities without any issue.
  • Quick and easy access
    Designed to boost efficiency the Galaxy Xcover4 features an intuitive Active Key that gives users speedy access to their preferred apps. Personalize the key function to open the camera or LED torch light in a flash thanks to its smart functionality.
  • Seamless transactions with NFC
    With NFC integration the Galaxy Xcover4 doubles as your wallet to make paying for purchases or transportation super easy. Simply swipe your device at the counter or subway turnstile to fulfill the transaction and never worry about being without money again.
  • Packs more power
    Power made to deliver even longer usage times to maximize enjoyment. The Galaxy Xcover4 comes equipped with a great battery to ensure you have plenty of charge to keep your workflow or content streaming going without interruption.
  • Absolute privacy
    Spend less time worrying and more time enjoying with peace of mind protection. Samsung Knox features passport-grade security so you can rest assured that your device is defended from real-time malware threats that put your data and privacy constantly at risk.
Samsung Galaxy Xcover 4 - black - 4G - 16 GB - GSM - smartphone
Smartphone 4G
Manufacturer Model Number
SM-G390F
Display
LCD display - 1280 x 720 pixels - 5" - TFT
Rear-facing camera, front-facing camera
1.4 GHz (quad-core)
16 GB - RAM 2 GB + microSDXC slot - up to 256 GB
Operating System
Google Android
Rear Camera
13 Megapixel - CMOS - f/1.9 - focus: automatic
Front Camera
5 Megapixel - CMOS f/2.2
Service Provider
Not specified
Rugged
SIM Card Type
Micro SIM
SIM Card Qty
Single-SIM
Wireless Interface
NFC, Wi-Fi, Bluetooth
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Talk Time
Up to 1020 minutes
Protection
Dustproof, splashproof, waterproof
73.3 mm x 9.7 mm x 146.2 mm
172 g
SAR
1.24 W/kg (body) / 0.611 W/kg (head)
Smartphone
SM-G390F
Touch - Rugged
Protection
Integrated Components
Rear-facing camera, front-facing camera, audio player, voice recorder, navigation
73.3 mm
9.7 mm
146.2 mm
172 g
Body Colour
SAR Value
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Google Android
Navigation
GPS, GLONASS, BeiDou
SIM Card Type
Micro SIM
SIM Card Qty
Single-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
GSM 850/900/1800/1900
3G UMTS Band
Band 1, Band 2, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 850, 900
4G LTE Band
Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 38, Band 40
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2600, TDD 2300
Wireless Interface
NFC, IEEE 802.11a/b/g/n, Bluetooth 4.2
Bluetooth Profiles
HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
Phone Functions
Speakerphone, call timer, conference call, flight mode, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, geomagnetic sensor
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Clock Speed
1.4 GHz
Processor Core Qty
Quad-core
RAM
2 GB
Internal Memory Capacity
16 GB
User Memory
10.1 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
5 Megapixel
Sensor Type
CMOS
Lens Aperture
F/2.2
Rear Camera
Sensor Resolution
13 Megapixel
Sensor Type
CMOS
Lens Aperture
F/1.9
Focus Adjustment
Automatic
Light Source
Flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps
Display
LCD display
TFT
Diagonal Size
5"
Display Resolution
1280 x 720 pixels
Display Format
HD
Colour Depth
16.7 million colours
Connector Type
Headset jack - mini-phone 3.5mm , Micro-USB - 5 pin Micro-USB Type B
2800 mAh
Talk Time
1020 minutes
Run Time Details
Active online usage (3G): up to 11 hrs , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (video): up to 13 hrs , Playback (audio): up to 77 hrs , Talk (WCDMA): up to 1020 min
IEC 60529 IP68
Power adapter
Model: Xcover 4
Screen Size: 5in
Brand: Samsung
Price Range Ex VAT: 150 - 300
