Enjoy peace of mind in any conditions with the incredibly robust Xcover3. Designed to withstand the rigors of both water and dust, the IP67-certified Xcover3 is equally at home on building sites, desert roads and ski slopes.
Thanks to the Xcover3's 2200 mAh battery, you can make the most of your phone for even longer without having to worry about recharging - for extended usage times while on the go.
Enjoy an improved grip with the Xcover3, easier to hold in one hand thanks to its slim 9.95 mm-thick body. Its sturdy-yet-stylish design also boasts exceptional practicality. Its USB ports and ear jack are waterproof even when uncovered, making life easier for you, no matter what the conditions have in store.
Simple controls
The Xcover3 is designed for ease of use in every scenario - even if you are wearing gloves. Simply use the Xcover Key to access your most frequently used apps. The dedicated Key allows you to control the functions with minimal fuss. -
Lightning-fast LTE
With support for LTE Cat4, the Xcover3 offers download speeds of up to 150 Mbps and upload speed of up to 50 Mbps. Enjoy surfing the web, downloading apps, watching movies, playing games and more - all at ultra-fast speed.
- Samsung Galaxy Xcover 3 - 4G smartphone - 8 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G388F
- Display
- LCD display - 800 x 480 pixels - 4.5" - TFT - scratch-resistant glass
- Processor
- 1.2 GHz (quad-core)
- Memory
- RAM 1.5 GB / 8 GB
- Supported Memory Card
- microSDXC slot - up to 128 GB
- Operating System
- Google Android
- Main Camera
- 5 Megapixel focus: automatic
- Front Camera
- 2 Megapixel - CMOS
- Service Provider
- Not specified
- Form Factor
- Rugged
- SIM Card
- Micro SIM
- Wireless Interface
- Wi-Fi, NFC, Bluetooth
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 600 minutes
- Protection
- Dustproof, waterproof
- 70.1 mm x 9.95 mm x 132.9 mm
- 154 g
- Specific Absorption Rate (SAR)
- 0.71 W/kg (head) , 0.39 W/kg (body)
- SAR Category (Belgium)
- B
- Product Type
- Smartphone
- SM-G388F
- Form Factor
- Touch - Rugged
- Protection
- 70.1 mm
- 9.95 mm
- 132.9 mm
- 154 g
- SAR Value
- 0.39 W/kg (body), 0.71 W/kg (head)
- B
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Google Android
- Navigation
- GPS, GLONASS
- SIM Card Type
- Micro SIM
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 3, Band 5, Band 7, Band 8, Band 20
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD
- IEEE 802.11b/g/n, NFC, Bluetooth 4.0
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, flight mode, vibrating alert
- Sensors
- Accelerometer, proximity sensor, geomagnetic sensor
Media Player
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA
- Supported Digital Video Standards
- MKV, MPEG-4, 3GP, H.264, H.263, M4V, WebM, 3G2
- Clock Speed
- 1.2 GHz
- Processor Core Qty
- Quad-core
- RAM
- 1.5 GB
- Internal Memory Capacity
- 8 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 128 GB
Front Camera
- Sensor Resolution
- 2 Megapixel
- Sensor Type
- CMOS
Main Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
- Camera Modes
- Panoramic pictures, sport mode, Beauty mode, Aqua mode
- Video Resolutions
- 1280 x 720 (720p)
Display
- LCD display
- Technology
- TFT
- Diagonal Size
- 4.5"
- Display Resolution
- 800 x 480 pixels
- Colour Depth
- 16.7 million colours
- Protection
- Scratch-resistant glass
- Connector Type
- Headset jack - mini-phone 3.5mm , Micro-USB - 5 pin Micro-USB Type B
- Capacity
- 2200 mAh
- Talk Time
- 600 minutes
- Run Time Details
- Active online usage (WCDMA): up to 9 hrs , Active online usage (LTE): up to 9 hrs , Active online usage (Wi-Fi): up to 13 hrs , Playback (video): up to 10 hrs , Playback (Music): up to 85 hrs , Talk (WCDMA): up to 600 min
- IP67, MIL-STD 801G
- Included Accessories
- Power adapter
- -30 °C
- 49 °C
- 0 - 95%
