The mini wall mount is your single-mount solution for a wide range of Samsung TVs. A one-time installation will place your TV in a straight and sturdy position.
Minimal depth
So slim, it's practically invisible. The nearly seamless design of the mini will take your TV from ordinary to extraordinary. An ultra-slim depth of 0.7" - 1.6" from the wall creates a profile that you have to see for yourself. -
VESA compatible
The mini wall mount is also VESA compatible, which allows you to hang any standard TV with VESA mounting holes onto the wall mount. Recommended for compatible Samsung models only. -
Convenient design
Pivot your TV left or right to adjust it according to the setup of your room. Adjust your wall mount the same way you would adjust a picture frame, using the back stand to tilt your TV upward. Use it to easily plug in cables on the side and behind your TV.
- Samsung WMN450M mounting kit - for flat panel
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-65"
- Max Load Weight
- 49.9 kg
- Designed For
- Samsung PN51F8500, PN60F8500, PN64F8500, UN32F5000, UN32F6300, UN39FH5000, UN40F5000, UN40F6300, UN40F6350, UN40F6400, UN46F5500, UN46F6400, UN46F6800, UN50F5000, UN50F5500, UN50F6300, UN50F6350, UN50F6400, UN50F6800, UN55F6350, UN55F6800, UN55F7100, UN55F7500, UN60F6300, UN60F7050, UN60F8000
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 32"-65"
- Adjustments
- Tilt
- Max Load Weight
- 49.9 kg
- Adjustable depth, pivot
- Designed For
- Samsung PN43F4500, PN51E550, PN51E6500, PN51E8000, PN51F4500, PN51F5300, PN51F5500, PN51F8500, PN60E530, PN60F5500, PN60F8500, PN64F5300, PN64F5500, PN64F8500, UN32EH4003, UN32EH5000, UN32EH5300, UN32F5000, UN32F5500, UN32F6300, UN39FH5000, UN40EH5000, UN40EH5300, UN40ES6500, UN40F5000, UN40F5500, UN40F6300, UN40F6350, UN40F6400, UN46EH5000, UN46EH5300, UN46EH6000, UN46ES6500, UN46F5000, UN46F5500, UN46F6300, UN46F6400, UN46F6800, UN46F7100, UN46F7500, UN46F8000, UN50EH5000, UN50EH5300, UN50EH6000, UN50ES6500, UN50F5000, UN50F5500, UN50F6300, UN50F6350, UN50F6400, UN50F6800, UN55EH6000, UN55ES6150, UN55F6300, UN55F6350, UN55F6400, UN55F6800, UN55F7100, UN55F7500, UN55F8000, UN60EH6000, UN60EH6003, UN60ES6100, UN60ES7500, UN60F6300, UN60F6400, UN60F7050, UN60F7100, UN60F7500, UN60F8000, UN65EH6000, UN65ES8000, UN65F6300, UN65F6400, UN65F7100, UN65F8000
