The Samsung SEW-3037W is an easy to use wireless baby monitoring system consisting of a high resolution 3.5" LCD monitor and wireless "night vision" camera with non-visible IR LEDs ensure safe night time monitoring. The camera unit features VGA (640 x 480) resolution to provide crisp and clear image and built-in mic and speaker of the camera allows two-way talk and you can talk to and hear your baby.
The SEW-3037W ensures long range transmission up to 900ft, allows you to monitor your baby at a distance. The monitor unit has LED on its front panel which indicates the level of sound so that you do not miss sound from your baby. And the pan and tilt of the camera can be operated from a parent unit with the button on the monitor so that you can adjust the view remotely. Up to 4 cameras can expanded with a monitor unit, the SEW-3037W will be a perfect solution to care the safety of your baby.
Pan, tilt & zoom
The SEW-3037W baby camera supports pan and tilt function for your convenience! With this function, you can locate your baby remotely without concerning camera coverage. This function can be operated from a parent unit with the button on the monitor. Also, you can look your baby more closely by using zoom function that supports 2x. Now, do not worry about your baby's location and movement, the SEW-3037W baby camera can follow your baby! -
Interference-free up to 900 ft
Parents can be assured that the pure digital signal provides secure and interference free video of your baby. And with a range of 900ft, you have the freedom to do what you have to do without losing signal. Unlike other devices, the pure digital signal allows the SEW-3037W baby monitor to function uninterrupted by wireless routers, microwaves, or cordless phone. Parents can be assured that nothing will cause an interruption in to the monitoring and caring for their baby. -
Two way talk
You hear your baby stirring but you can't get to him or her right away. With the SEW-3037W monitor, not only can you hear your baby but you can talk to your baby too. With two way talk feature, soothe him or her with the sound of your voice. -
Watching your baby even in the dark
The SEW-3037W camera has night vision capability and you can keep an eye on your baby even at low or no light conditions. In addition to the night vision capability, the SEW-3037W baby monitor has a remote activated night light on the camera. Keep an eye on your baby, even in the dark. -
Best image available
Samsung is known for their high resolution display technology. The baby camera unit for SEW-3037W displays video with VGA (640 x 480) resolution for a clear and crisp video image...
- SAMSUNG TECHWIN SafeVIEW SEW-3037W - baby monitoring system - wireless
- System
- Baby monitoring system - wireless - 2.4 GHz
- Monitor
- 3.5" LCD monitor (TFT) - colour
- Camera
- 1 cameras - indoor - PAL - night vision
- 167 g
- System
- Wireless Frequency Band
- 2.4 GHz
- 2-way audio, volume control, built-in microphone, Vox (Voice activated transmission)
- Package Content
- Camera, 2 power adapters, Monitor
Monitor
- Diagonal Size
- 3.5"
- Technology
- LCD monitor
- LCD Technology
- TFT
- Image Resolution
- 320x240
Cameras
- Quantity
- 1 cameras
- Camera Type
- Indoor
- Sensor
- CMOS - 1/5" - 640x480
- Field of View
- 56°
- TV System
- PAL
- Sensitivity (lux)
- 2
- Night Vision
- Infrared LEDs
- White Balance
- Auto
- Focal Length
- 3 mm
- Voltage
- DC 6 V
- Current Consumption
- 320 mA
- -10 °C
- 40 °C
- Operating Humidity
- 0-85%
- 167 g
- Details
- Camera: 214 g , Monitor: 167 g
