Your basket is empty
Samsung Wireless Charging Station - White
Quicklinx: BKT2WS00 Mfr#: EP-PG920IWEGWW
Unlike most conventional chargers, this Samsung Wireless Charging pad is both unique and beautiful in design. Its clear, glass-look details and glossy finish add a touch of sophistication, and allows it to fit in well with a variety of interior settings.
Charging your phone is easier than ever with the Samsung Wireless Charger. No need to connect a cable to your smartphone - simply place your mobile device on the charger pad and watch it charge, so easy.
Samsung Wireless Charger helps keeping that minimal clutter-free look easy. It looks great wherever you use it - the living room, the office or the bedroom.
Samsung EP-PG920I - wireless charging mat
Wireless charging mat
1.68 cm
Diameter
9.7 cm
87.5 g
5 V
Voltage Provided
5 V
Galaxy Note5, S6, S6 Active, S6 edge, S6 edge+, S7, S7 edge
1.68 cm
Diameter
9.7 cm
87.5 g
Enclosure Colour
White
5 V
Input Connectors
5 pin Micro-USB Type B
Voltage Provided
5 V
Max Electric Current
1000 mA
LED indicator
WPC, Qi
Samsung Galaxy Note5, S6, S6 Active, S6 edge, S6 edge+, S7, S7 edge
