The Wireless Charger Duo Pad has the improved Fast Wireless Charging 2.0 capabilities. It charges your phone faster than previous Samsung wireless chargers so you can get back to 100%, faster.
Charge yourself and a friend
Recharge your phone and your watch at the same time. Or lend a charger spot to a friend. There are two distinct charging zones, so you can easily charge two phones, a phone and your watch, or whatever configuration you may need. -
Compatible with Qi devices
Because it's engineered to be Qi-compatible, this charger makes it simple to recharge your other devices without taking up another plug. Basically, if your device can be charged wirelessly, it likely works on the Wireless Charger Duo Pad.
- Samsung Wireless Charger Duo Pad EP-P5200 wireless charging mat - + AC power adapter
- Product Type
- Wireless charging mat + AC power adapter
- 19.5 cm x 9.2 cm x 1.805 cm
- 168 g
- Black
- Voltage Required
- 12 V
- Voltage Provided
- 5 / 10 V
- Max Electric Current
- 2.1 A
- Fast Charge Technology
- Fast Charge
- Wireless Charging
- Wireless Charging Standards
- Qi, Fast Wireless Charging, Fast Wireless Charging 2.0
- Cables
- USB-C cable - 1.2 m
- Designed For
- Samsung Gear S3; Galaxy Note5, Note8, Note9, S10, S10+, S10e, S6, S7, S8, S8+, S9, S9+, Watch, Watch Active
- Product Type
- Designed For
- Mobile phone, smart watch
- 19.5 cm
- 9.2 cm
- 1.805 cm
- 168 g
- Enclosure Colour
- Black
- Voltage Required
- 12 V
- Input Connectors
- 24 pin USB-C
- Voltage Provided
- 5 / 10 V
- 2.1 A
- Wireless Charging
- Fast Charge
- AC Power Adapter Included
- Simultaneous dual wireless charging
- Cables Included
- Designed For
- Samsung Gear S3 Classic, Gear S3 Frontier , Samsung Galaxy Note5, Note8, Note8 Dual SIM, Note8 DUOS, Note9, Note9 (without "unlock" packaging), Note9 Enterprise Edition, Note9 Ultimate Edition, Note9 Unlocked, S10, S10 (Unlocked), S10 Enterprise Edition, S10+, S10+ (Unlocked), S10e, S10e (Unlocked), S10e Enterprise Edition, S6 edge+, S7, S7 Active, S7 edge, S8, S8 Active, S8+, S9, S9 Deluxe Edition, S9 Enterprise Edition, S9+, S9+ Deluxe Edition, Watch, Watch Active
