Hear the full, rich sound of your favorite music from anywhere in the room. Designed in Samsung's state-of-the-art audio lab in California, the Radiant 360 speaker uses breakthrough ring radiator technology to equally project exquisite audio in all directions so wherever you move, you're always in the sweet spot. Stream your favorite music from your mobile device using the Multiroom App 2.0 via Wi-Fi to the Radiant 360 speaker system.
Ring radiator technology
Enjoy rich sounds from anywhere in the room with patented ring radiator technology. Dual acoustic lenses transmit audio from the speaker in a 360° direction, making everywhere in the room the sweet spot. -
Breakthrough design
Designed in state of the art California Audio Lab, the Radiant 360 is expertly engineered with patented technology to fill each room with rich sound, while its sleek style seamlessly blends with your home's décor. -
360° speaker
Conventional speakers transmit sound from only one side of the device and need to be rearranged for optimum sound projection. The Samsung Radiant 360 projects 360 degree, omnidirectional sound, making anywhere in the room ideal for enjoying the ultimate audio experience.
- Samsung Wireless Audio Radiant 360 R7 - speaker - wireless
- Product Type
- Speaker
- Localisation
- United Kingdom
- Speaker Type
- 2-way - active
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- DLNA
- Audio Formats
- WAV, WMA, AAC, AIFF, MP3, FLAC, OGG, ALAC
- Speaker Details
- Speaker - mono - active
- White
- 18.1 cm x 18.1 cm x 42.2 cm
- 3.4 kg
- 1-year warranty
- Product Type
- Speaker
- Enclosure Colour
- White
- Localisation
- United Kingdom
Speaker System
- Speaker Type
- 2-way - active
- Amplifier
- Integrated
- Bluetooth, Wi-Fi
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 10 m
- DLNA
- Audio Formats
- Controls
- Input selector, power on/off, volume, play/pause
- Additional Features
- 360° omni-directional, smartphone remote controlled, TV SoundConnect technology, MultiRoom support (WHA), Ring Radiator Technology
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: woofer driver - 5" , Speaker: tweeter driver - 1"
- Connector Type
- Service (5 pin Micro-USB Type B)
- Included Accessories
- AC power adaptor
- Power Source
- AC power adapter
- 18.1 cm
- 18.1 cm
- 42.2 cm
- 3.4 kg
- Limited warranty - 1 year
