See stunningly natural and lifelike pictures through Samsung’s UHD Crystal Color technology meeting various quality standards. This screen technology delivers enhanced pixels and chip set for a superior picture quality experience with stunning contrast and over 17 million true to life colors with intense shades in a color space wider than conventional UHD.
HDR
The advanced standard for UHD content is High Dynamic Range. UHD TVs that are HDR compliant can all display the content but not all HDR TVs are equal. HDR combined with Crystal Color provides a superior High Dynamic Range experience delivering stunning brightness, enhanced shadow detail and naturally accurate color. -
Cloud gaming
Does your TV open up the world of console-less video gaming? Who needs a games console when you can access a wealth of video games from the cloud straight to your TV? Access a huge array of games without the need to invest in a console. Play alongside your favorite stars and race against advanced racing drivers, directly through your TV. -
UHD Upscaling
Samsung's unique 4 step UHD Upscaling process converts live TV, your movies and gaming to high resolution, transforming what you watch to premium picture quality. The technology identifies the specific process required to the input signal, noise reduction and upscaling to convert the source material into the UHD resolution of the TV. The last step dedicates resources of the processor to specific areas of the picture requiring detail enhancement. Samsung UHD Upscaling engine raises all conventional content to more impressive quality and with fast and powerful processors it delivers the very best in UHD picture quality. -
UHD Dimming
UHD Dimming technology divides the screen into small zones, analyzing each one to adjust color, brightness and sharpness, so you can experience a better picture. The software driven technology improves picture contrast without compromising the overall brightness of the rest of the scene. -
Ultra Clean View
Ultra Clean View analyzes the input signal and removes detected noise from the feed. No matter what quality the signal Ultra Clean View improves what you see. -
Accelerate your Smart TV with Tizen
Tizen takes Smart TV performance to another level with faster boot times and quick access to Live TV and all your apps. It even provides support for popular local VOD apps for optimized TV viewing. -
Dive into your video content
Auto Motion Plus works together to provide enhanced motion with the key motion technologies, image processing speed, backlight technology and frame refresh rate. The end result is impressive clarity for action scenes and sport. -
Simple and fast wireless connection
The built-in Wireless Lan lets you connect your Smart TV to the Internet without the tangle of cables. With the streamlined connections, now you can really enjoy your TV's outstanding design. -
Plug your entertainment into the TV
Using ConnectShare, you can watch a variety of content in one simple step. Just plug your USB or HDD into the TV and enjoy your movies, music, and pictures on the big screen. -
Create your own entertainment space
Samsung TVs support HDMI inputs, which lets you create a multimedia entertainment center in your own living room. Connect HDMI straight into your TV to view various contents from multiple devices.
- Samsung UE65KU6400U 6 Series - 65" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 65"
- Silver
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 1500 Picture Quality Index, 100 Hz Motion Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- LED backlight UHD dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Multi-channel Preview
- Picture-in-picture (PIP)
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Samsung TM1640A remote control, batteries, Samsung TM1240A remote control
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A+
- 195 Watt
- Power Consumption (On mode)
- 118 W
- Energy Consumption per Year
- 164 kWh
- Dimensions (WxDxH) - without stand
- 145.81 cm x 5.49 cm x 84.14 cm
- 23.5 kg
- Product Type
- Energy Class
- Class A+
- 195 Watt
- 118 W
- 164 kWh
- Diagonal Class
- 65"
- Series
- 6 Series
- HDR Capable
- Video Processor
- Quad-Core
- TV Tuner
- TV Tuner Presence
- Extended PVR
- Sensors
- Eco Sensor
- Video Interface
- HDMI Ports Qty
- 3 ports
- Modes
- Game mode, Film Mode
- Design
- Very Narrow Bezel Design (VNB)
- Dimensions
- Without stand
- 145.81 cm
- 5.49 cm
- 84.14 cm
- 23.5 kg
- Enclosure Colour
- Silver
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Contrast enhancer, time-shift, HDMI quick switch, USB Cloning, Auto Motion Plus, Digital Clean View, E-Manual, UHD Upscaling, Instant On, Mega Dynamic Contrast Ratio, Embeded POP, Ultra Clean View, Accessibility Enlarge, Accessibility High contrast, Accessibility Voice guide, Active Crystal Color
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- MPEG Profiles and Levels
- MHEG5
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Remote Control Model
- Samsung TM1640A
- Additional remote control included
Audio System
- Digital Audio Format
- DTS digital output, Dolby Digital Plus output
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Audio Return Channel (ARC), Bass Reflex Speaker System, Wallmount Sound Mode, TV Soundconnect
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), Samsung Smart View, ConnectShare
- Supported Consumer Electronics Control (CEC)
- Anynet Plus, Multiroom Link
- DLNA
- Connector Type
- 3 x HDMI , 2 x USB 2.0 , Composite video / component video input , LAN , Digital audio output (optical) , Audio line-in
- Batteries, Samsung TM1240A remote control
- Power Device
- Power supply
- Input Voltage
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.81 cm x 5.49 cm x 84.14 cm x 23.5 kg , Panel with stand - 145.81 cm x 32.77 cm x 90.94 cm x 26.8 kg
- Width (Shipping)
- 172.1 cm
- Depth (Shipping)
- 16.8 cm
- Height (Shipping)
- 94.7 cm
- Weight (Shipping)
- 34.8 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
