This UHD Nano Crystal TV delivers much more color than standard UHDs, creating amazingly lifelike scenes with true to life tones and great detail. This true UHD screen offers color range that meets the high industry standards emitting the pure light source delivering increased brightness levels, colors and content as the director intended. With the picture quality that offers much more detail than Full HD, the JU6800 produces stunningly bright and clear images. Enjoy a picture that is optimized for even greater clarity and detail than you've ever seen before.
Finally, thanks to the Samsung SUHD Picture Engine, you can enjoy various kinds of content with the UHD-level picture quality, even if it's not from a UHD source. Samsung's processing engine enhances broadcasting TV shows and movies as well as video on demand and more. That means not only does it process UHD sources at crisp 4K resolution, it even converts lower-resolution content to a level of clarity that's almost like Ultra High Definition.
Sensational Nano Crystal Color
UHD Nano Crystal TV delivers much more color than standard UHD, creating amazingly lifelike scenes with true to life tones and great detail. This true UHD screen offers color range that meets the high industry standards emitting the pure light source delivering increased brightness levels, colors and content as the director intended. -
Outstanding UHD picture quality experience
With picture quality that offers much more detail than Full HD, the JU6800 produces stunningly bright and clear images. Enjoy a picture that is optimized for even greater clarity and detail than you've ever seen before. -
Contrast enhancer
Flat images come to life with the Samsung's contrast enhancer. Your TV intelligently applies varying levels of contrast enhancement to different areas and objects on the screen creating a dramatic 3D-like effect. -
UHD upscaling enhances the quality of all of your viewing
Thanks to the Samsung SUHD Picture Engine, you can enjoy various kinds of content with the UHD-level picture quality, even if it's not from a UHD source. Samsung's processing engine enhances broadcasting TV shows and movies as well as video on demand and more. That means not only does it process UHD sources at crisp 4K resolution, it even converts lower-resolution content to a level of clarity that's almost like Ultra High Definition. -
Your TV and mobile devices in perfect sync
Samsung Easy Sharing makes it easy to share content between your TV and mobile. Whether it's a fun video or that must-see TV show Samsung Smart TV picks up the signal when your device is close and seamlessly plays the content perfect for the big screen. It works the other way around, too, so you can move about your house while viewing your favorite content on your device. -
A more detailed picture made for UHD resolution
Samsung's advanced UHD dimming technology brings the ideal level of contrast and color to your UHD viewing. The higher resolution of UHD also means that the picture requires more processing for a highly detailed image. That's why Samsung UHD dimming technology has been developed to process black and white as optimally as possible, and produce colors that are far more vivid. -
Powerful quad-core performance
Thanks to its powerful quad core processor, your Samsung Smart TV offers enhanced performance. Enjoy faster multitasking and switch between content and web browsing. Also, you'll notice smoother experience when interacting with your TV.
- Samsung UE60JU6800K 6 Series - 60" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 60"
- Silver
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight UHD dimming
- Digital TV Tuner
- DVB-C, DVB-T2
- Multi-channel Preview
- Picture-in-picture (PIP)
- Speaker System
- 2 speakers
- Sound Effects
- DTS Studio Sound, DTS Premium Sound 5.1
- USB
- 3 ports
- Included Accessories
- Samsung TM1250A remote control, batteries
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A+
- 310 Watt
- Power Consumption (On mode)
- 99 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 137 kWh
- Dimensions (WxDxH) - without stand
- 136.36 cm x 6.4 cm x 78.95 cm
- 21.8 kg
- Product Type
- Energy Class
- Class A+
- 310 Watt
- 99 W
- 137 kWh
- Diagonal Class
- 60"
- Series
- 6 Series
- Video Processor
- Quad-Core
- TV Tuner Presence
- Extended PVR
- Sensors
- Eco Sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Game mode, Film Mode, Natural Mode, Sports Mode Advanced
- Dimensions
- Without stand
- 136.36 cm
- 6.4 cm
- 78.95 cm
- 21.8 kg
- Enclosure Colour
- Silver
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Contrast enhancer, time-shift, ultra clear panel, BD Wise Plus, Auto Motion Plus, Digital Clean View, PurColor, UHD Upscaling, Instant On, Mega Dynamic Contrast Ratio, Embeded POP, Nano Crystal Colour, Ultra Clean View
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T2
- HDTV Tuner
- Digital TV Service
- HbbTV
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Samsung TM1250A
Audio System
- Digital Audio Format
- DTS digital output, Dolby Digital Plus output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Bass-reflex, Down-firing Speaker, TV Sound Connect, Wallmount Sound Mode
- Speakers
- 1 x left channel speaker - 10 Watt , 1 x right channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Connect & Share
- Wi-Fi Direct, USB Human Interface Device (HID), Samsung Smart View, ConnectShare
- Supported Consumer Electronics Control (CEC)
- Anynet Plus
- Application Store
- Samsung Apps
- DLNA
- Connector Type
- 4 x HDMI , 3 x USB 2.0 , Headphones , Composite video / component video input , Audio line-in , Digital audio output (optical) , LAN
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
- WOL (Wake on LAN)
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 136.36 cm x 6.4 cm x 78.95 cm x 21.8 kg , Panel with stand - 136.36 cm x 36.94 cm x 85.5 cm x 23.9 kg
- Width (Shipping)
- 168.7 cm
- Depth (Shipping)
- 17.6 cm
- Height (Shipping)
- 92 cm
- Weight (Shipping)
- 30.7 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
