Your basket is empty
Samsung UE60JU6800K 60" 6 Series LED Smart TV 4K UHDTV (2160p) - Silver
Quicklinx: BMNCWS00 Mfr#: UE60JU6800KXXU
This UHD Nano Crystal TV delivers much more color than standard UHDs, creating amazingly lifelike scenes with true to life tones and great detail. This true UHD screen offers color range that meets the high industry standards emitting the pure light source delivering increased brightness levels, colors and content as the director intended. With the picture quality that offers much more detail than Full HD, the JU6800 produces stunningly bright and clear images. Enjoy a picture that is optimized for even greater clarity and detail than you've ever seen before.
Finally, thanks to the Samsung SUHD Picture Engine, you can enjoy various kinds of content with the UHD-level picture quality, even if it's not from a UHD source. Samsung's processing engine enhances broadcasting TV shows and movies as well as video on demand and more. That means not only does it process UHD sources at crisp 4K resolution, it even converts lower-resolution content to a level of clarity that's almost like Ultra High Definition.
Samsung UE60JU6800K 6 Series - 60" LED TV
LED-backlit LCD TV - Smart TV
Diagonal Class
60"
Silver
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN
PC Interface
Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
LED backlight - UHD dimming
Digital TV Tuner
DVB-C, DVB-T2
Multi-channel Preview
Picture-in-picture (PIP)
Speaker System
2 speakers
Sound Effects
DTS Studio Sound, DTS Premium Sound 5.1
USB
3 ports
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A+
310 Watt
Power Consumption (On mode)
99 W
Energy Consumption per Year
137 kWh
136.36 cm x 6.4 cm x 78.95 cm
21.8 kg
Energy Class
Class A+
310 Watt
99 W
137 kWh
Diagonal Class
60"
Series
6 Series
Extended PVR
Sensors
Eco Sensor
Video Interface
HDMI Ports Qty
4 ports
PC Interface
HDCP Compatible
Modes
Game mode, Film Mode, Natural Mode, Sports Mode Advanced
Dimensions
Without stand
136.36 cm
6.4 cm
78.95 cm
21.8 kg
Enclosure Colour
Silver
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Contrast enhancer, time-shift, ultra clear panel, BD Wise Plus, Auto Motion Plus, Digital Clean View, Quad-Core processor, PurColor, UHD Upscaling, Instant On, Mega Dynamic Contrast Ratio, Embeded POP, Nano Crystal Colour, Ultra Clean View
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T2
Digital TV Service
HbbTV
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
3
Remote Control
Standard remote
Remote Control Model
Samsung TM1250A
Audio System
Digital Audio Format
DTS digital output, Dolby Digital Plus output
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Bass-reflex, Down-firing Speaker, TV Sound Connect, Wallmount Sound Mode
Speakers
1 x left channel speaker - built-in - 10 Watt , 1 x right channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Connect & Share
Wi-Fi Direct, USB Human Interface Device (HID), Samsung Smart View, ConnectShare
Supported Consumer Electronics Control (CEC)
Anynet Plus
Application Store
Samsung Apps
DLNA
Connector Type
4 x HDMI , 3 x USB 2.0 , Headphones , Composite video / component video input , Audio line-in , Digital audio output (optical) , Network
Batteries
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by
0.3 Watt
Auto On/Off
WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 136.36 cm x 6.4 cm x 78.95 cm x 21.8 kg , Panel with stand - 136.36 cm x 36.94 cm x 85.5 cm x 23.9 kg
Width (Shipping)
168.7 cm
Depth (Shipping)
17.6 cm
Height (Shipping)
92 cm
Weight (Shipping)
30.7 kg
Cables (5)
BMNC C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BMNC C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.04
BMNC C2G 5m Select High Speed HDMI with Ethernet In Stock £10.55
BMNC C2G 10m Select High Speed HDMI with Ethernet In Stock £32.40
BMNC C2G 15m Select High Speed HDMI with Ethernet In Stock £43.91
Other bundles (1)
BMNC C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
