Samsung UE55D 55" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: 9X6MWS00 Mfr#: LH55UEDPLGC/EN
  • 1080p
The Samsung UE55D features a stylishly thin chassis with a slim bezel to bezel (BtB) spec, combined with an upgraded Samsung SMART Signage Platform. Create beautiful video walls in full HD with no PC, DVD or SBB required. Built-in Wi-Fi allows for easy mobile control and increased Daisy Chain capability, while compatibility with the predecessor UE-C models provides versatile options.
  • Edge-Lit LED display
    The edge-lit 55" display of the UE55D features full HD resolution to deliver sharp, detail-rich images and crisp type. The narrow bezels, at 11mm BtB, elegantly complement the visuals thanks to minimal distraction.
  • Enhanced SSP with quad core processor
    Experience 2x SoC performance thanks to SSP with a quad core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs.
  • Ultra-slim 1.2" chassis
    A stylishly thin chassis helps to create sophisticated videowalls that can inspire your audience. The ultra-slim design also helps to simplify installation while meeting ADA compliance requirements.
  • PC-Less Videowalls
    Create beautiful video walls with no PC, DVD or SBB. Use only USB with Display Port 1.2 Loop In/Out. Users can benefit from the simplified process and less equipment requirements for videowall installation and content playing.
  • Built-In Wi-Fi
    Experience easy mobile control and increased Daisy Chain capability thanks to built-in Wi-Fi. Use AllShare Cast (sold separately) over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display.
Samsung UE55D UE-D Series - 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
USB
Remote control
Voltage
Energy Class
Class B
154 Watt
Power Consumption (On mode)
120 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
175 kWh
122.24 cm x 3.13 cm x 69.32 cm
13.3 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
154 Watt
120 W
175 kWh
Diagonal Class
55"
Commercial Use
Series
UE-D Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Design
Narrow Bezel Design
Dimensions
Without stand
122.24 cm
3.13 cm
69.32 cm
13.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, Smart Scheduling, e-LED BLU, MagicInfo Player-S2
Video Wall
225
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback
Wi-Fi
Connector Type
Serial input , Serial output , Remote control/ambient sensor input , Audio line-in , Audio line-out , USB 2.0 , HDMI input , DisplayPort input , DisplayPort output , DVI-D input , VGA input , Composite video / component video / audio input , LAN , Remote control output
DisplayPort cable
Plug and Play, TUV, C-Tick, GOST, cUL, DDC-2B, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, EN55024, UL 60950, CISPR 22, CB, CCC, EMC, PSB, EK, AS/NZS 3548, IRAM, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, GB 9254-2008, GB 17625.1-2003 EMC, KCC KN22, KCC KN24, K60950, GB 4943.1, IS13252, NOM-001-SCFI-1993, BIS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
134 cm
Depth (Shipping)
14.5 cm
Height (Shipping)
80 cm
Weight (Shipping)
17.8 kg
10 - 80%
