Samsung UD55E-S 55" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BWYHWS00 Mfr#: LH55UDEOLBB/EN
  • 1080p
To eliminate the color irregularities that can diminish professional quality broadcasts, Samsung's UDE-S video wall features advanced factory tuning, amazing hardware and exceptional user calibration tools. A multi-step factory calibration process ensures high-performing uniform brightness and color consistency out-of-the-box, preventing studios from having to waste time and energy making adjustments. When exposed to the unique lighting conditions of enclosed broadcast studio environments, video wall panels can run the risk of losing image quality due to irregular color expression. Samsung's high-quality UDE series panels offer the ultimate viewing experience. UDE-S video wall's special panel features a lower color value temperature range to ensure optimized color expression for broadcast cameras. This flexible low temperature operation expands choice and enables the adjustment of color expression depending on the situation. As a result, broadcasters can enhance news footage and graphic presentation to provide their audiences the ultimate viewing experience.
In fast-paced broadcast settings, studios must be able to quickly adjust and locate frequently used display settings to transition from various content types. Samsung's UDE-S video wall enables smoother and simpler navigation of commonly used picture settings through home menu designed to accommodate the specific needs of broadcast environments. The user-friendly interface enables the convenient updating and customization of picture settings for a variety of real-time content formats, resulting in the better overall performance of broadcasts. Samsung's UDE-S video wall combines superior performance, clarity and non-distracting presentation to engage viewing audiences. Designed for dependable 24/7 operation, the UDE-S supports dynamic content with a consistent picture quality and color presentation, making it ideal for round-the-clock newsrooms and broadcast studio environments. The display's high brightness also creates a more immersive viewer experience through brilliant, life-like imagery and visual content. Similarly, the display's bezel-to-bezel screen design keeps UDE-S viewers' attention focused on featured content rather than the display itself with a nearly seamless presentation. By combining a sophisticated design with enhanced dependability, high brightness and a non-distracting bezel design, the UDE-S fosters an unparalleled entertainment experience that benefits broadcasters and their viewers.
  • Maintain professional picture quality and consistency
  • Achieve realistic color presentation through specialized, low-temperature panel
  • Customize picture settings through easily-navigable home menu for broadcasters
  • Engage your viewers through a brilliant, seamless and reliable presentation
Samsung UD55E-S 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Advanced Color Management (ACM), Image Rotation, Magic Clone, Auto Source Switching & Recovery
Remote control, batteries
Voltage
Energy Class
Class D
Power Consumption (On mode)
239 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
349 kWh
121.35 cm x 9.66 cm x 68.43 cm
23.3 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class D
239 W
349 kWh
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
121.35 cm
9.66 cm
68.43 cm
23.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
8 ms
Commercial Features
Pivot, digital daisy chain, MagicInfo, Smart Scheduling, d-LED BLU, MagicInfo Player-S3, 10 x10 Daisy-Chain support
Video Wall
225
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Connector Type
VGA input , DVI-D input , 2 x HDMI input , DisplayPort input , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out , Remote control
Batteries
DisplayPort cable
Plug and Play, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, K60950-1, KCC KN22, KCC KN24, CNS 13438, GB 4943-2011, GB 17625.1-2012, IEC 60590-1, CAN/CSA-C22.2 No. 60950-1
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
Panel without stand - 121.35 cm x 9.66 cm x 68.43 cm x 23.3 kg
Width (Shipping)
145 cm
Depth (Shipping)
38.5 cm
Height (Shipping)
90.3 cm
Weight (Shipping)
36.9 kg
10 - 80%
