Samsung UD55E-P 55" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BWYCWS00 Mfr#: LH55UDEPLBB/EN
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
  • 1080p (Full HD)
£3,402.33 ex VAT
£4,082.79 inc VAT
Samsung's UDE Series video wall, UDE-P, features advanced factory tuning, innovative hardware and exceptional user calibration tools. Samsung's multi-step factory calibration process tunes video wall displays to the highest-performing uniform brightness and color across each display out-of-the-box. The enhanced panel quality of Samsung's UDE-P video wall elevates visual messaging and content through a seamless image and superior clarity. Featuring an ultra-narrow 3.5 mm bezel-to-bezel design format (2.3 mm bezel on the left and top sides and 1.2 mm bezel on the right and bottom sides), which is the slimmest bezel in the video wall industry, the display creates a virtually uninterrupted viewing experience to keep audiences focused on content rather than the display itself. Businesses face increased challenges to capture the attention of passers-by with impactful content, particularly in large, often crowded retail and public environments. By combining the ultimate in picture quality with unparalleled multiscreen display connectivity, the Samsung UDE-P video wall garners heightened exposure for messaging by captivating viewers. The display transforms standard Full-High Definition (FHD) content into a powerful Ultra-High Definition (UHD) viewing experience for the enhanced effectiveness and impact of message deployment. Featuring integrated DisplayPort (DP) 1.2 ports, the UDE-P can showcase high-quality UHD content across multiple screens simultaneously without requiring additional external devices. This improved capability and flexibility generates opportunities for businesses to share memorable content without adding cost or complexity. As an all-in-one solution, the Samsung UDE-P video wall ensures users can create, deploy and manage an array of highly-impactful content without separate external PCs or devices. With a built-in media player through its embedded chip, 3rd Generation SSSP, the UDE-P uses its powerful Quad Core CPU to streamline digital content operation and improve total cost of ownership (TCO). As a result, content managers can easily install the video wall and begin sharing content with target audiences with minimal expense or hassle. Samsung's versatile UDE-P Series video walls come equipped with a range of user-friendly features to ensure a seamless installation complementary to your specific operational needs. The displays come with an industry-leading slim, 39 mm depth video wall mount for easy installation and calibration to hold each display in place without distracting viewers. As the wall mount is sized to the dimensions of the video wall, users can simply install the mount first and fit into the video wall. This user-friendly design eliminates the need to measure the wall mount and calculate the gap to properly size, which can be experienced with standard video wall mounting systems.
  • Showcase superior picture quality through advanced factory color calibration
    Any irregularity in brightness and color accuracy across video wall displays can negatively impact the viewing experience. To eliminate such color expression gaps and maintain a fully-aligned, consistent and captivating presentation, Samsung's UDE Series video wall, UDE-P, features advanced factory tuning, innovative hardware and exceptional user calibration tools. Samsung's multi-step factory calibration process tunes video wall displays to the highest-performing uniform brightness and color across each display out-of-the-box. After calibration, these displays offer an industry-leading local uniformity of more than 90 percent across 25 (5 x 5) areas of each screen, resulting in uninterrupted color expression across the entire display. The calibration process also maintains a superior white balance difference of less than 300 degrees K, while simultaneously achieving detailed color in grayscale through multi-step gamma calibration. In addition to rigorous factory calibration, users can manage brightness and color uniformity conveniently with Samsung Color Expert, a powerful free software program. Through these advanced solutions, the UDE Series video walls maintain superior uniformity, consistency and performance for the ultimate in color expression within large-scale presentations.
  • Captivate audiences through a narrow bezel and optimized panel design
    The enhanced panel quality of Samsung's UDE-P video wall elevates visual messaging and content through a seamless image and superior clarity. Featuring an ultra-narrow 3.5 mm bezel-to-bezel design format (2.3 mm bezel on the left and top sides and 1.2 mm bezel on the right and bottom sides), which is the slimmest bezel in the video wall industry, the display creates a virtually uninterrupted viewing experience to keep audiences focused on content rather than the display itself. When exposed to a range of environmental conditions, video wall panels can run the risk of losing image quality due to distortion and irregular color presentation. To provide consistent display clarity uninterrupted message delivery in any operational environment, Samsung's UDE-P video wall panels undergo rigorous performance testing. Each display features a reinforced panel that deters heat, weather and other stress-inducing conditions. As a result, Samsung's superior panel prevents screen darkening, light leakage or any related deterioration in picture quality. An anti-glare panel also enables messages to reach relevant audiences with minimal distraction by light reflection. All these enhanced panel quality features allow for the long-term delivery of brilliant contents and the ultimate viewing experience.
  • Captivate viewers through UHD content and enable cost-efficient management without special devices
  • Vivid and reliable content delivery for the needs of your business
    Designed to maintain consistent performance in varying indoor environment conditions, Samsung's UDE-P video wall produces an engaging and impactful premium viewing experience. The video wall's elevated contrast ratios and high brightness of 700 nit produce consistent, crystal-clear picture quality and a vivid color presentation regardless of surrounding lighting conditions. With continuous 24/7 operational performance and dependability, the UDE-P can deliver immersive content when and where it is most effective for your unique business needs. This combination of embedded design benefits makes the UDE-P a smart choice for content delivery in business settings where enhanced readability is essential.
  • Simplified content creation and management through all-in-one, embedded platform
    As an all-in-one solution, the Samsung UDE-P video wall ensures users can create, deploy and manage an array of highly-impactful content without separate external PCs or devices. With a built-in media player through its embedded chip, 3rd Generation SSSP, the UDE-P uses its powerful Quad Core CPU to streamline digital content operation and improve total cost of ownership (TCO). As a result, content managers can easily install the video wall and begin sharing content with target audiences with minimal expense or hassle. Additionally, Samsung's advanced MagicInfo S3 content management software comes integrated with the 3rd Generation SSSP. Compatible with a wide range of image, text and video file formats and sizes, MagicInfo S3 simplifies the content creation and server-to-screen upload process for added convenience. The user-friendly program also ensures a visual fit for any environment through an extensive library of widgets, stickers, stamps and font styles, which simplifies the customization of content that reinforces the user's industry and brand.
  • A slim, easily configurable wall mount adaptive to your business needs
    Samsung's versatile UDE-P Series video walls come equipped with a range of user-friendly features to ensure a seamless installation complementary to your specific operational needs. The displays come with an industry-leading slim, 39 mm depth video wall mount for easy installation and calibration to hold each display in place without distracting viewers. As the wall mount is sized to the dimensions of the video wall, users can simply install the mount first and fit into the video wall. This user-friendly design eliminates the need to measure the wall mount and calculate the gap to properly size, which can be experienced with standard video wall mounting systems. Once installed, the mounting system offers three-dimensional axis tuning, including x-axis; y-axis (left and right with rail movement); and z-axis (push and pull pop-up capability), for effortless alignment of individual displays to form a continuous, gap-free presentation. This dimensional consistency and easy adjustability also prevents the need to dismantle the entire video wall should one specific section require adjustment.
Samsung UD55E-P UDE-P Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Advanced Color Management (ACM), Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
USB
Remote Control
Standard remote
Voltage
Energy Class
Class D
297 Watt
Power Consumption (On mode)
227 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
331 kWh
121.53 cm x 9.66 cm x 68.43 cm
23.3 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class D
297 Watt
227 W
331 kWh
Diagonal Class
55"
Commercial Use
Series
UDE-P Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
100
Dimensions
Without stand
121.53 cm
9.66 cm
68.43 cm
23.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, Smart Scheduling, key lock, MagicInfo Player-S3
Stands & Mounts
VESA Mounting Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , DisplayPort input , DisplayPort output , Composite video / component video / audio input , 2 x HDMI input , Audio line-in , Audio line-out , Remote control
Batteries
DisplayPort cable
Plug and Play, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, UL 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, KN22, KN24, K60950-1, GB4943.1-2011, GB 17625.1-2012, IEC60950-1
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
0.5 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Width (Shipping)
145 cm
Depth (Shipping)
38.5 cm
Height (Shipping)
90.3 cm
Weight (Shipping)
36.9 kg
10 - 80%
Video Interface: Composite
Video Interface: HDMI
Brand: Samsung
Price Range Ex VAT: 1500+
