Samsung UD55E-B 55" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BWYGWS00 Mfr#: LH55UDEBLBB/EN
  • 1080p
The Samsung UD55 advances LCD video wall technology by reducing the bezel-to-bezel (BtB) spec from 5.5mm to 3.5mm compared to predecessor models. Along with factory-tuned color calibration for consistency across multiple displays and the embedded SMART Signage Platform (SSP), you can efficiently achieve seamless matrices, while LED backlighting reduces power consumption in large installations.
  • 3.5mm BtB ultra-narrow bezel width
    The UD55D features incredibly thin bezels at a mere 2.3mm (L/T) and 1.2mm (R/B) - 3.5mm bezel-to-bezel - shaving more than 33% off its predecessor model. Create virtually seamless video walls for a more elegant and impactful delivery of your message.
  • Samsung SMART Signage Platform (SSP)
    Embedded SSP SoC technology helps to reduce the cost and complexity of installation and maintenance by streamlining hardware and software requirements. As an integrated, open platform, you can eliminate the need for external media players to display content across video walls.
  • Color calibration
    Samsung factory color calibration helps to minimize color difference among mulitple LFDs. Factory-tuned for brightness, color temperature and gamma, you can experience color uniformity right out of the box for consistent video wall messaging.
  • Advanced Color Management (ACM)
    The ACM solution provides a user-friendly interface to implement customized and detailed color adjustments. Control luminance, temperature and gamma through auto calibration, manual calibration and duplication to achieve the perfect display for your business.
  • Video wall
    Create video walls up to 10x10 for large, impactful messaging. Easily connect multiple displays in an elegant fashion thanks to the streamlined hardware and software requirements of the embedded SSP SoC technology and the ultra-narrow bezels of the UD55D.
  • Achieve UHD resolution
    Daisy Chain up to 4 displays over Display Port 1.2 (DP 1.2 - Loop-Out) to achieve 4K x 2K Ultra High Definition (UHD - 3840x2160) resolution. Display exceptional content in a sophisticated manner for an enhanced customer experience.
  • Image rotation
    Enjoy convenient content creation and management. Create your desired content on a single display and turn on Image Rotation to transform portrait orientation into horizontal and vice versa when you connect and split-screen multiple displays in a video wall matrix.
  • Magic Clone
    Save installation time for multiple displays with Magic Clone. Simply enter your display settings the first time, save the setting information to a USB or external HDD and plug in the external device to the other sets to install them equally.
Samsung UD55E-B 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Remote control, batteries
Voltage
Energy Class
Class G
Power Consumption (On mode)
190 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
257 kWh
121.35 cm x 9.66 cm x 68.43 cm
23.3 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class G
190 W
190 kWh/1000h
257 kWh
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
121.35 cm
9.66 cm
68.43 cm
23.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
8 ms
D-LED BLU, 10 x10 Daisy-Chain support
Video Wall
225
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Connector Type
VGA input , DVI-D input , 2 x HDMI input , DisplayPort input , DisplayPort output , Audio line-in , Serial , Audio line-out , Remote control
Batteries
DisplayPort cable
CSA, UL, TUV, C-Tick, GOST, EN55022, NEMKO, NOM, PCBC, SASO, EN55024, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24, K60950-1, CAN/CSA-C22.2 No. 60950-1
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
145 cm
Depth (Shipping)
39.5 cm
Height (Shipping)
89.2 cm
Weight (Shipping)
36.9 kg
10 - 80%
