Samsung UD55D LFD with FHD can take your digital messaging to the next level thanks to unsurpassed Samsung bezel innovation. This 3.5 mm bezel display can amaze audiences when combined together to form seamless video walls with virtually no visual distraction. From 4 meters (13 feet) away UD55D bezel is invisible to the naked eye creating a truly uninterrupted image for optimized visual messaging. Use this display technology to entice customers into your retail shop, replace traditional whiteboards in your corporate meeting room or provide important real-time information in public places. Additionally, provide highly bright, vibrant picture quality without glare or blurriness to completely captivate audiences with a powerful viewing experience.
Deliver your messages in consistently accurate color across multiple displays with Samsung UD55D LFD. The display undergoes a meticulous factory color calibration process, ensuring accurate color without image distortion without the need for manual calibration. The improved factory color-tuning for white balancing and color difference compensation ensure that the display presents image in uniform color with color temperature matching. For users who want to fine-tune the colors, Samsung advanced color management offers more detailed management. Color vibrancy can be calibrated automatically or manually. Color values can be shared between multiple displays, ensuring outstanding intensity across all video wall screens that can impress the audience. Combined with the anti-glare panel that reduces light scatter to make messages more readable, UD55D LFD can effectively deliver your content in the vibrant, accurate color to impress your audience.
Provide seamless viewing with unprecedented 3.5 mm bezel width
Samsung UD55D LFD with FHD can take your digital messaging to the next level thanks to unsurpassed Samsung bezel innovation. This 3.5 mm bezel display can amaze audiences when combined together to form seamless video walls with virtually no visual distraction. From 4 meters (13 feet) away UD55D bezel is invisible to the naked eye creating a truly uninterrupted image for optimized visual messaging. Use this display technology to entice customers into your retail shop, replace traditional whiteboards in your corporate meeting room or provide important real-time information in public places. Additionally, provide highly bright, vibrant picture quality without glare or blurriness to completely captivate audiences with a powerful viewing experience. -
Amaze your viewers with accurate color across multiple displays
Deliver your messages in consistently accurate color across multiple displays with Samsung UD55D LFD. The display undergoes a meticulous factory color calibration process, ensuring accurate color without image distortion without the need for manual calibration. The improved factory color-tuning for white balancing and color difference compensation ensure that the display presents image in uniform color with color temperature matching. For users who want to fine-tune the colors, Samsung advanced color management offers more detailed management. Color vibrancy can be calibrated automatically or manually. Color values can be shared between multiple displays, ensuring outstanding intensity across all video wall screens that can impress the audience. Combined with the anti-glare panel that reduces light scatter to make messages more readable, UD55D LFD can effectively deliver your content in the vibrant, accurate color to impress your audience. -
Display content optimally with easy image rotation
Whether using a single display or a video wall, you can create content in portrait or landscape mode - and then rotate it. Samsung display includes a pivot and image rotation function that display content vertically or horizontally, without ratio distortion. Conveniently rotate your content with three display options: original ratio on a single screen, full ratio on a single screen, or full ratio on a video wall. -
Connect multiple displays without picture quality loss through DisplayPort 1.2 support
Join up to 100 displays without losing picture quality with the DisplayPort (DP) 1.2 multistream support. By using DP 1.2, businesses can display content in ultra high definition (UHD) of 3,840 x 2,160 in 2 x 2 video walls without additional equipment. The High-bandwidth Digital Content Protection (HDCP) daisy-chain capability offered on UDC series displays helps reduce the cost of deploying multiple displays. With the HDCP support, LiveTV, Blu-ray Disc and other HDCP content can be presented without an HDCP distributor.
- Samsung UD55D UD-D Series - 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with built-in PC
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform, Image Rotation, Magic Clone
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 209 Watt
- Power Consumption (On mode)
- 180 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 263 kWh
- Dimensions (WxDxH) - without stand
- 121.35 cm x 9.66 cm x 68.43 cm
- 23.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class C
- 209 Watt
- 180 W
- 263 kWh
- Diagonal Class
- 55"
- Commercial Use
- Combined With
- Built-in PC
- Series
- UD-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 121.35 cm
- 9.66 cm
- 68.43 cm
- 23.3 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Direct-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3500:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.63mm
- Response Time
- 8 ms
- Pivot, digital daisy chain, MagicInfo Lite, Advanced Color Management, MagicInfo Premium-S, MagicInfo Videowall-S
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
- Configuration
- ARM Cortex-A9 ( 1 GHz ) - 1 GB DDR3 - 8 GB
- 8 GB
Remote Control
- Remote control
- Connector Type
- 2 x HDMI input , Composite video / component video / audio input , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
- Cables Included
- VGA cable
- Plug and Play, DDC-2B, ISO 9241-307
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - parts and labour - 3 years - on-site
- Width (Shipping)
- 145 cm
- Depth (Shipping)
- 38.5 cm
- Height (Shipping)
- 90.3 cm
- Weight (Shipping)
- 36.9 kg
