Samsung UD55C-B 55" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Quicklinx: B4TTWS00 Mfr#: LH55UDCBLBB/EN
  • 1080p
Therobust and reliable Samsung UDC-B LFD series displays enable businesses to convey their messages with vivid color accuracy. Astound your viewers with consistently brilliant imagery and color across all displays in the video wall, delivered on a near-seamless canvas with a super-narrow bezel of 5.5 mm. With UDC-B series displays, you can use the display solution of your choice on the video wall to deliver your content in the optimal way you want. For even greater impact, creatively configure the video wall to captivate your audience. Retailers and entertainment venues may showcase a more artistic configuration, while control centers and corporations may display a more standard video wall. Regardless of setup, your message will dazzle audiences on a bright, sleek, energy-efficient video wall.
  • Deliver your message in full high definition with minimal distractions
    With super-narrow bezels of just 5.5 mm (0.22), UDC-B series displays create a near-seamless viewing experience for vivid digital images and messaging, helping audiences absorb your message with minimal distraction. The slender depth of the displays makes the video wall easily adaptable to various environments. The displays also include an anti-glare panel with an 11 percent haze level, which reduces light scatter and dazzling for enhanced readability. The brilliant image projected in a brightness of 450 CD with Samsung's direct LED (d-LED) BLU (backlight unit) technology will capture your audience's attention with its immersive quality.
  • Impress viewers with the color uniformity across all screens
    Deliver your messages in consistently accurate color across multiple displays with Samsung UDC-B series displays. The displays undergo a meticulous factory color calibration process, ensuring accurate color without image distortion without the need for manual calibration. The improved factory color-tuning for white balancing and color difference compensation ensure that the displays present image in uniform color with color temperature matching.
  • Display clear messages
    D-LED technology featured in UDC-B Series displays not only projects your message in brilliant picture quality with vivid and uniform color definition, it also reduces your energy costs. Consuming less power on average compared with conventional cold cathode fluorescent lamp (CCFL) LFDs, d-LED displays generate less heat, making them more comfortable to be around.
  • Keep your message playing with automatic source switching
    The auto source switching feature of UDC-B series displays maintains virtually constant and seamless content display. This feature automatically changes the display from one content source to another when the original source fails. Source recovery enables a content source to be used as a backup for ongoing play when another source is unavailable. This flexibility ensures that your business content remains available when you need it.
  • Manage content on a video wall of up to 10 x 10 displays with ease
    Using the DVI loop out, you can share content shown on a single display with adjoining displays in your video wall. Instead of manually programming each unit in the video wall, you can remotely control content on UDC-B series displays. This innate connectivity eliminates the need for you to purchase separate video signal distributors for each display, reducing equipment costs. Easily change your message as often as needed to support your business and to reach your target audience.
  • Minimize viewing distractions with narrow bezels
    Heighten the impact of visual product and messages with UEC series displays narrow bezels. The bezels as narrow as 11.2 mm from bezel to bezel help create a near-seamless digital canvas, providing audiences a superior viewing experience with minimal distractions. The sleek, stylish display can fit in naturally in the environment with its unobtrusive design.
Samsung UD55C-B UDC-B Series - 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
Direct-lit LED
TV Tuner
No tuner
Commercial Features
Button lock, Auto Source Switching & Recovery, Lamp Error Detection
Remote control
Voltage
Energy Class
Class B
165 Watt
Power Consumption (On mode)
155 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
226.3 kWh
121.53 cm x 11.38 cm x 68.61 cm
24.3 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
165 Watt
155 W
226.3 kWh
Diagonal Class
55"
Commercial Use
Series
UDC-B Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
121.53 cm
11.38 cm
68.61 cm
24.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Direct-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, Anti Retention, Smart Scheduling, Advanced Color Management
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Connector Type
VGA input , DVI-D input , 2 x HDMI input , Component video input , Composite video input , Audio line-in , DVI-D output , Audio line-out , Serial , Remote control , Remote control/ambient sensor input
VGA cable
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, GB 17625.1-2003 EMC, KN22, KN24, K60950-1, CAN/CSA-C22.2 No. 60950-1
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0 Watt
Width (Shipping)
144 cm
Depth (Shipping)
37.5 cm
Height (Shipping)
87 cm
Weight (Shipping)
35.1 kg
10 - 80%
