UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box.
The minimized bezel gap of just 5.5 mm is crucial to the virtually seamless video wall experience that the UD-C series delivers. It's ideal for control rooms, the medical sector, and conference rooms, broadcasting stations, transportation hubs, lobbies and retail.
Advanced color calibration
UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box. -
DisplayPort 1.2
The digital loop out feature allows you to easily share content across video walls up to 10x10; including the ability to fully support Ultra High Definition resolution on 2 x 2 video walls. It is an easy and cost effective way to connect multiple displays. -
Sharp, bright, impactful
Full HD 1920 x 1080 resolution and brightness ensure a clear, vibrant video wall that's easy to look at and hard to ignore. -
Direct-lit LED
Direct-lit LED technology with a new backlight dimming solution allows the UD-C series display to achieve deeper blacks, higher contrast ratio of 3500:1, and power savings of up to 30%. -
Ultra-slim bezels, virtually seamless video walls
- Samsung UD55C UD-C Series - 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with built-in PC
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform, Image Rotation, Magic Clone
- Settings Cloning Capability
- Storage Drive Capacity
- 2.8 GB
- Storage Capacity
- 2.8 GB
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 220 Watt
- Power Consumption (On mode)
- 175 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 256 kWh
- Dimensions (WxDxH) - without stand
- 121.53 cm x 9.6 cm x 68.61 cm
- 24 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class C
- 220 Watt
- 175 W
- 256 kWh
- Diagonal Class
- 55"
- Commercial Use
- Combined With
- Built-in PC
- Series
- UD-C Series
- Video Processor
- Dual-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 121.53 cm
- 9.6 cm
- 68.61 cm
- 24 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Direct-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 3500:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.63mm
- Response Time
- 8 ms
- Pivot, Certified for 24/7 Continuous Operation, MagicInfo Lite, DID technology, Advanced Color Management, MagicInfo Premium-S, MagicInfo Videowall-S, d-LED BLU
Video Wall
- 100
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
- Configuration
- ARM Cortex-A9 ( 1 GHz ) - 1 GB DDR3 - 2.8 GB
- 2.8 GB
Remote Control
- Remote control
- Connector Type
- 2 x DisplayPort , 2 x HDMI , DVI-Digital , VGA input , Composite video input , Component video input , Serial , Remote control , Audio line-out , Audio line-in , USB 2.0
- Cables Included
- VGA cable
- Plug and Play, DDC-2B, ISO 9241-307
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years - on-site
- Width (Shipping)
- 145 cm
- Depth (Shipping)
- 38.5 cm
- Height (Shipping)
- 90.3 cm
- Weight (Shipping)
- 41.6 kg
