Samsung UD55C 55" 1920x1080 VGA DVI HDMI DP VESA 700CD LED LFD
Quicklinx: 9HN7WS00 Mfr#: LH55UDCPLBB/EN
  • 1080p
UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box.
The minimized bezel gap of just 5.5 mm is crucial to the virtually seamless video wall experience that the UD-C series delivers. It's ideal for control rooms, the medical sector, and conference rooms, broadcasting stations, transportation hubs, lobbies and retail.
  • Advanced color calibration
  • DisplayPort 1.2
    The digital loop out feature allows you to easily share content across video walls up to 10x10; including the ability to fully support Ultra High Definition resolution on 2 x 2 video walls. It is an easy and cost effective way to connect multiple displays.
  • Sharp, bright, impactful
    Full HD 1920 x 1080 resolution and brightness ensure a clear, vibrant video wall that's easy to look at and hard to ignore.
  • Direct-lit LED
    Direct-lit LED technology with a new backlight dimming solution allows the UD-C series display to achieve deeper blacks, higher contrast ratio of 3500:1, and power savings of up to 30%.
  • Ultra-slim bezels, virtually seamless video walls
Samsung UD55C UD-C Series - 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with built-in PC
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
Direct-lit LED
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone
Settings Cloning Capability
Storage Drive Capacity
2.8 GB
Storage Capacity
2.8 GB
USB
Remote control
Voltage
Energy Class
Class C
220 Watt
Power Consumption (On mode)
175 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
256 kWh
121.53 cm x 9.6 cm x 68.61 cm
24 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class C
220 Watt
175 W
256 kWh
Diagonal Class
55"
Commercial Use
Combined With
Built-in PC
Series
UD-C Series
Video Processor
Dual-Core
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
121.53 cm
9.6 cm
68.61 cm
24 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Direct-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63mm
Response Time
8 ms
Commercial Features
Pivot, Certified for 24/7 Continuous Operation, MagicInfo Lite, DID technology, Advanced Color Management, MagicInfo Premium-S, MagicInfo Videowall-S, d-LED BLU
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Configuration
ARM Cortex-A9 ( 1 GHz ) - 1 GB DDR3 - 2.8 GB
2.8 GB
Remote Control
Remote control
Connector Type
2 x DisplayPort , 2 x HDMI , DVI-Digital , VGA input , Composite video input , Component video input , Serial , Remote control , Audio line-out , Audio line-in , USB 2.0
VGA cable
Plug and Play, DDC-2B, ISO 9241-307
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years - on-site
Width (Shipping)
145 cm
Depth (Shipping)
38.5 cm
Height (Shipping)
90.3 cm
Weight (Shipping)
41.6 kg
