Samsung UD46E-P 46" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BWY8WS00 Mfr#: LH46UDEPLBB/EN
  • 1080p (Full HD)
Samsung's UDE-P SMART Signage video wall capitalizes on a world of untapped business possibilities with simplified content development, consistent color accuracy and premium large-scale visuals. Designed for indoor corporate venues, public settings and retail outlets, this professional-grade video wall enables businesses to schedule and deploy timely content for maximum impact, 24/7. Backed by the 3rd Generation Samsung SMART Signage Platform (SSSP), the UDE-P supports convenient message creation without requiring extra effort or equipment. Samsung's UDE-P video wall also elevates on-screen content through rigorous factory and user-calibrated color management technologies that deliver uniform picture quality. Along with high brightness and an ultra-narrow bezel, this video wall's impressive visual impact keeps audiences focused on content rather than the display itself. Through this unique combination of benefits, Samsung's UDE-P video wall allows businesses to seamlessly create and deliver a variety of digital content that is sure to resonate with target audiences.
  • Designed for 24/7 operation
    Communicate with customers 24/7 thanks to increased durability and reliability.
  • 700nit brightness
    700-nit brightness allows you to broadcast vivid, highly legible images and visual messaging in a range of lighting conditions.
  • 3.5 mm ultra narrow bezel
    Featuring the slimmest bezel in the video wall industry, an ultra-narrow 3.5 mm bezel-to-bezel design format (2.3 mm bezel on the left and top sides and 1.2 mm bezel on the right and bottom sides), UDE-P displays create a virtually uninterrupted viewing experience that keeps audiences focused on content rather than on the display itself.
  • Advanced factory calibration
    Any irregularity in brightness and color accuracy will impact the video wall viewing experience. To eliminate these types of color expression inconsistencies, Samsung's UDE Series video walls feature advanced factory tuning and innovative hardware. After calibration, these displays offer an industry-leading local uniformity of more than 90 percent across a 5x5 grid of each display screen, which translates into uniform color expression across the entire display setup.
  • Best-in-class panel quality
    UDE-P's V-PID panel ensures superior display quality by preventing panel blackening even after long periods of use. Additionally, these panels undergo rigorous pre-calibration to guarantee your content is captivating and distraction-free.
  • 3rd Generation Samsung SMART Signage Platform (SSSP)
    3rd Generation SSSP is an integrated System on Chip (SoC) media player that streamlines digital signage configuration and management by eliminating the need for an additional PC Unit. 3rd Generation SSSP comes equipped with a powerful Quad Core processor and 8 GB of storage for convenient, easy usage, resulting in enhanced operational efficiency, rich, high-resolution media content and lowered TCO.
Samsung UD46E-P UDE-P Series - 46" LED display - Full HD
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Max Number Of Screens
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
USB
Remote control, batteries
Voltage
Energy Class
Class C
Power Consumption (On mode)
142 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
207 kWh
102.21 cm x 9.74 cm x 57.66 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
142 W
207 kWh
Diagonal Class
46"
Commercial Use
Series
UDE-P Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
225
102.21 cm
9.74 cm
57.66 cm
18 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, Smart Scheduling, Advanced Color Management, MagicInfo Player-S3, 10 x10 Daisy-Chain support, d-LED DID
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Connector Type
RGB input , DVI-D input , DisplayPort input , DisplayPort output , Composite video / component video / audio input , 2 x HDMI input , Audio line-in , Audio line-out , Multiple Display Control , Serial , USB
Batteries
DisplayPort cable
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, GOST, cUL, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, KN22, KN24, K60950-1, GB4943.1-2011, GB 17625.1-2012, NOM-019-SCFI-1993, CAN/CSA-C22.2 No. 60950-1
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
116 cm
Depth (Shipping)
28 cm
Height (Shipping)
71.5 cm
Weight (Shipping)
22.4 kg
10 - 80%
