Samsung UD46D-P 46" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Quicklinx: B4TSWS00 Mfr#: LH46UDDPUBB/EN
  • 1080p
Samsung UD46D-P SMART signage with FHD can take your digital messaging to the next level thanks to unsurpassed Samsung bezel innovation. These never before seen bezel displays can amaze audiences when combined together to form seamless video walls with virtually no visual distraction. The UD46D-P bezels are invisible to the naked eye creating a truly uninterrupted image for optimized visual messaging. Use this cutting-edge display technology to entice customers into your retail shop, replace traditional whiteboards in your corporate meeting room or provide important real-time information in public places. Additionally, provide highly bright, vibrant picture quality without glare or blurriness to completely captivate audiences with a powerful viewing experience.
  • Provide seamless viewing
  • Simplify content delivery with a hassle-free all-in-one video wall solution
    Improve productivity and reduce operating costs by installing and configuring the signage solution with greater ease. The embedded, all-in-one eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership. In addition, the SSSP supports a picture-in-picture for operational excellence. To boost efficiency, content deployment and sharing is simplified with a PC-less network connection that lets you plug in a USB and link multiple displays over a daisy chain configuration.
  • Easily manage digital signage
    Frequently used functions are conveniently available on the Home screen in a matrix design represented by large menu buttons for ease of use. A selection of menu configurations is also displayed on the Home screen, which can be customized to populate repeatedly used menus instead of using the default selection, for quick access. UD46D-P SMART signage also provides powerful content management tools, upgraded for your business use.
  • Amaze your viewers with pinpoint color accuracy across multiple displays
    Maintaining consistent color across multiple displays becomes easier for businesses with UDD Series displays. The displays undergo a meticulous factory color calibration process, ensuring accurate color without image distortion and without the need for manual calibration. The improved factory color tuning for white balancing and color difference compensation ensure that the displays present images in uniform color with color temperature matching. Users can fine-tune the colors with Samsung Color Expert, which offers more detailed management for any custom needs and provides added convenience by reducing calibration time. Color vibrancy can be calibrated automatically or manually. Plus, color values can be shared between multiple displays, ensuring outstanding intensity across all video wall screens, dazzling the audience.
  • Display content optimally with easy image rotation
    Whether using a single display or a video wall, you can create content in portrait or landscape mode - and then rotate it. UDD Series displays include a pivot function and image rotation function that display content vertically or horizontally without ratio distortion. You can conveniently and accurately rotate your content with display options: original ratio on a single screen, full ratio on a single screen or full ratio on a video wall.
Samsung UD46D-P UD-D Series - 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
Direct-lit LED
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection, SMART Signage Platform 2nd Generation
Settings Cloning Capability
Supported Memory Cards
SD Memory Card
USB
Remote control
Voltage
Energy Class
Class C
Power Consumption (On mode)
130 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
190 kWh
102.21 cm x 9.7 cm x 57.67 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
130 W
190 kWh
Diagonal Class
46"
Commercial Use
Series
UD-D Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
102.21 cm
9.7 cm
57.67 cm
18 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Direct-lit LED
Coating
Anti-glare
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Dynamic Contrast Ratio
10000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, Anti Retention, MagicInfo, DID technology, Smart Scheduling, Advanced Color Management, MagicInfo Videowall-S, MagicInfo Player-S2
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Remote control
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
2 x HDMI input , Composite video / component video / audio input , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
DisplayPort cable
Plug and Play, FCC Class B certified, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, FCC Part 15 B, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, ISO 9241-307, KCC, CSA C22.2 No. 60950-1, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, KN22, KN24, K60950-1, CNS 13438, IEC60950-1, GB 17625.1-2011, GB4943.1-2001
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
125.5 cm
Depth (Shipping)
35.5 cm
Height (Shipping)
79.8 cm
Weight (Shipping)
22.4 kg
10 - 80%
