UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box.
The minimized bezel gap of just 5.5 mm is crucial to the virtually seamless video wall experience that the UD-C series delivers. It's ideal for control rooms, the medical sector, and conference rooms, broadcasting stations, transportation hubs, lobbies and retail.
Advanced color calibration
UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box. -
DisplayPort 1.2
The digital loop out feature allows you to easily share content across video walls up to 10x10; including the ability to fully support Ultra High Definition resolution on 2 x 2 video walls. It is an easy and cost effective way to connect multiple displays. -
Sharp, bright, impactful
Full HD 1920 x 1080 resolution and brightness ensure a clear, vibrant video wall that's easy to look at and hard to ignore. -
Direct-lit LED
Direct-lit LED technology with a new backlight dimming solution allows the UD-C series display to achieve deeper blacks, higher contrast ratio of 3500:1, and power savings of up to 30%. -
Ultra-slim bezels, virtually seamless video walls
- Samsung UD46C-B UDC-B Series - 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 130 Watt
- Power Consumption (On mode)
- 120 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 175 kWh
- Dimensions (WxDxH) - without stand
- 102.37 cm x 9.55 cm x 57.83 cm
- 18.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- Energy Class
- Class C
- 130 Watt
- 120 W
- 175 kWh
- Diagonal Class
- 46"
- Commercial Use
- Series
- UDC-B Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 102.37 cm
- 9.55 cm
- 57.83 cm
- 18.2 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Colour Depth
- 16.7 million colours
- Dynamic Contrast Ratio
- 3500:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53025 x 0.53025mm
- Response Time
- 6.5 ms
- Certified for 24/7 Continuous Operation, Lamp Error Detection, anti-image retention
Video Wall
- 100
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Remote Control
- Remote control
- Connector Type
- VGA input , DVI-D input , 2 x HDMI input , Component video input , Composite video input , Audio line-in , DVI-D output , Audio line-out , Serial , Remote control , Remote control/ambient sensor input
- Cables Included
- VGA cable
- Plug and Play, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, GB 17625.1-2003 EMC, KN22, KN24, K60950-1, CAN/CSA-C22.2 No. 60950-1
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 125.5 cm
- Depth (Shipping)
- 35.5 cm
- Height (Shipping)
- 79.8 cm
- Weight (Shipping)
- 31.2 kg
- 0 °C
- 40 °C
- 10 - 80%
