The UD22B can be configured in video walls up to 10 x 10 for strikingly different and artistic messaging that draws customer attention. Smart scheduling enables video wall content control at all times with up to 3 programmable day/time calendars. The upgraded multi display control allows control of multiple monitors through the embedded RS232C and RJ45 interfaces.
Dramatic video walls
The UD22B can be configured in video walls up to 10 x 10 for strikingly different and artistic messaging that draws customer attention. -
Easily manage content
Smart scheduling enables video wall content control at all times with up to 3 programmable day/time calendars. The upgraded multi display control allows control of multiple monitors through the embedded RS232C and RJ45 interfaces. -
Reduced operating expenses
Highly efficient Direct-Lit LED backlighting technology produces high contrast levels for impactful messaging, but also generates less heat. That translates to reduced operating costs.
- Samsung UD22B 22" Class (21.6" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 22"
- Diagonal Size
- 21.6"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 960 x 960
- Video Interface
- Composite, HDMI
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 1:1
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Microsoft Certification
- Compatible with Windows 7
- Energy Class
- Class D
- 71.5 Watt
- Power Consumption (On mode)
- 63 W
- Energy Consumption per Year
- 92 kWh
- Dimensions (WxDxH) - without stand
- 39.33 cm x 7.95 cm x 39.33 cm
- 5.8 kg
- Product Type
- Energy Class
- Class D
- 71.5 Watt
- 63 W
- 92 kWh
- Diagonal Class
- 22"
- Diagonal Size
- 21.6"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 39.33 cm
- 7.95 cm
- 39.33 cm
- 5.8 kg
- Enclosure Colour
- Black
Display
- Resolution
- 960 x 960
- 1:1
- Edge-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 4000:1
- Dynamic Contrast Ratio
- 10000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.1345 x 0.1345mm
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 200 mm, 300 x 300 mm
Audio System
- Sound Output Mode
- Stereo
- Connector Type
- VGA input , DVI-D input , DisplayPort , HDMI , Composite video input , Audio line-in , DVI-D output , LAN , Serial
- Power Device
- Power supply
- Width (Shipping)
- 47.3 cm
- Depth (Shipping)
- 18.7 cm
- Height (Shipping)
- 47.3 cm
- Weight (Shipping)
- 7 kg
