Samsung U32H850UMU 31.5" 3840x2160 4ms HDMI DP MiniDP LED Monitor
Quicklinx: D7DSWS00 Mfr#: LU32H850UMUXEN
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mini DisplayPort
23 in stock
£442.76 ex VAT
£531.31 inc VAT
The UH85 has a resolution 4 times higher than Full HD. Its wider workspace allows you to view more webpages, images and texts with less scrolling and zooming. Also, see your 4K content the way it was meant to be seen, with a new level of life-like detail that makes you feel like you're really there.
The UH85's infinitesimal quantum dots in 1 billion hues create images in vivid and wide-ranging colors. Coming with refreshingly enriched greens and reds in particular, it simply better meets your professional needs especially in photo editing and graphic design.
  • Ultra high clarity
  • Quantum dots in 1B hues
  • PBP dual-screen function
    Samsung's Picture-by-Picture capabilities let you connect to two different devices at the same time while still maintaining the original image quality.
  • PIP sub-screen display
    The Picture-in-Picture feature allows you to do away with the need for a second monitor even when you are multitasking. You can resize the second image up to 25% of the screen and position it anywhere you wish.
  • Ergonomic design
    It swivels, tilts, pivots, and is height-adjustable, ready to meet the needs of any usage scenario. VESA - supported, it can be installed on a wall or separate arms with ease. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
  • Slim body, thin bezels
    Slim-bodied with narrow bezels and its back in matte black, coming complete with a graceful yet steadfast height-adjustable stand, the UH85 is a blend of performance and beauty that's built to cater to your business demands. Its urbane, modern appeal will seamlessly match any office interior.
  • Multiple USB 3.0 ports
    With its four USB 3.0 ports, you can transmit data between devices 10 times faster than you could with USB 2.0 ports. Two of these ports also enable you to recharge your tablet PCs, smartphones and other mobile devices in super-quick time - 3 times faster than USB 2.0 ports.
Samsung U32H850UMU - UH85 Series - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
89 kWh
Power Consumption (On mode)
61 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Black, silver
73.11 cm x 29.86 cm x 62 cm
8.8 kg
Environmental Standards
TCO Certified ENERGY STAR Qualified
Display Type
Energy Class
Class C
89 kWh
61 W
Diagonal Size
32"
Viewable Size
31.5"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Magic Upscale, Flicker Free technology, Image Size, USB Super-charging, OSD Auto Rotate, Factory Calibration, Eye Saver Mode, Factory Calibration Report, Off Timer Plus, 72% (NTSC 1976) colour gamut, Quantum Dot Technology, 125% sRGB colour gamut
Black, silver
73.11 cm x 29.86 cm x 62 cm - with stand
8.8 kg
DisplayPort , Mini DisplayPort , HDMI , Headphones , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+24
Swivel Angle
94
Rotation Angle
60
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
61 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 73.11 cm - depth: 29.86 cm - height: 62 cm - weight: 8.8 kg , Without stand - width: 73.11 cm - depth: 7.89 cm - height: 42.81 cm - weight: 6.9 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Samsung U32H850UMU 31.5 Bundle deal on Samsung U32H850UMU 31.5" 3840x2160 4ms HDMI DP MiniDP LED Monitor
£541.93
Diagonal Size: 32in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Samsung
Price Range Ex VAT: 300 - 500
