Product
Samsung U32E850R 31.5" 3840x2160 4ms HDMI DisplayPort USB 3.0 LED Monitor
Quicklinx: B8MRWS00 Mfr#: LU32E85KRS/EN
The UE850 UHD monitors offer rich picture contrast and rapid response time, creating a more life-like, non-distracting visual experience that simultaneously enhances performance. The UE850's improved resolution and dynamic connectivity drive efficiency for professional, creative and analytical tasks. Combined with ergonomic and environmentally-friendly advancements, these UE850 monitors deliver a complete, comfortable viewing experience.
  • Enhanced visual performance
    Through the presentation of more than 8 million pixels and four-times the detail clarity of full high-definition (FHD) alternatives, the UE850 provides the most accurate image recreation possible. Samsung's monitors create a true UHD viewing experience through a host of embedded picture- and game-enhancing functions. The UE850 are the only UHD monitors supporting AMD FreeSync technology, which synchronizes the refresh rate of the monitor to the frame rate of a user's AMD graphic card for a smooth, responsive and tearing-free game. Response times as fast as one millisecond in the 28-inch models also allows gamers to see even the fastest on-screen action clearly and smoothly without motion blur or ghosting, while a 60 Hz refresh rate further eliminates picture choppiness and fosters a smoother, non-distracting viewing environment.
  • Versatile multi-tasking connectivity
    By offering advanced connectivity, the UHD monitors expand user functionality for greater flexibility and convenience. While both UHD monitors have integrated DisplayPort (DP) and HDMI ports, UE850 business monitors feature a Quad interface that seamlessly connects with DP 2.1, miniDP, HDMI 2.0 and HDMI 1.4a sources. HDMI 2.0 and DP 2.1 support 4K resolution at 60Hz, which is double the maximum resolution of HDMI 1.4a (4K at 30Hz). The UE850 also comes with four USB 3.0 ports, with two offering super-charging capability. Since the super-charging USBs enable the simultaneous charging of multiple mobile devices that is three times faster than a normal USB 2.0 port, the need for a docking station is eliminated. As a result, professionals can upload and view almost any content type while concurrently charging multiple devices. To promote productivity, the UE850 allowes users to align on-screen content with their specific viewing needs. A picture-by-picture (PBP) mode ensures content can be displayed from two different input sources while maintaining picture quality. Similarly, up to 25 percent of the screen can be repositioned and resized anywhere within the screen using the Picture-in-picture 2.0 (PiP) mode.
  • Display comfort and functionality
    Improved ergonomic benefits deliver a more comfortable, enjoyable experience for UE850 users. The UHD monitors come with VESA-supported wall mounts, and the UE850 further extends viewing capabilities through a height-adjustable stand (HAS) and tilt, pivot and swivel capabilities. Professionals can also maintain aspect ratio consistency when pivoting the UE850 business monitor with a built-in auto on-screen display (OSD) rotation function and auto magic rotation software. Designed for extended periods of screen use, the UE850 make the viewing experience less strenuous. Using a unique eye-saver mode, the monitors reduce the harmful effects of blue light on viewers' eyes and associated eye strain. Similarly, the monitors' flicker-free function protects viewers' eyes from the constant strain of flickering screens that can be experienced with standard monitors.
  • Eco-friendly performance
    The UHD monitors reinforce Samsung's commitment to deliver high-performing technologies in a more sustainable manner. To help businesses conserve energy, resources and costs, the UE850 is constructed using 30 percent recycled plastic and a PVC-free body, while also featuring the energy-conserving technologies. The UE850's off timer plus function reduces power consumption and enables power-off scheduling, while the smart eco-saving function helps reduce screen brightness for increased energy efficiency.
Samsung UE850 Series U32E850R - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
89 kWh
Power Consumption (On mode)
62 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.1815 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Black, titan silver
74.03 cm x 27.86 cm x 49.35 cm
9.61 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, C-Tick, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, GB 17625.1, VCCI V-3, GB 9254-2008, TCO Displays 6.0, K60950-1, KCC KN22, KCC KN24, CNS 14336, CNS 13438, GB 4943-2011
Display Type
Energy Class
Class B
89 kWh
62 W
Diagonal Size
31.5"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1815 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, picture by picture, MagicRotation, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, BFR/PVC-free, Image Size, PIP 2.0, USB Super-charging, Eye Saver Mode, 97% sRGB colour gamut
Black, titan silver
74.03 cm x 27.86 cm x 49.35 cm - with stand
9.61 kg
Headphones , 2 x HDMI , DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+22
Swivel Angle
50
Rotation Angle
-1.5/+91.5
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
AC 120/230 V
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 74.03 cm - depth: 27.86 cm - height: 49.35 cm - weight: 9.61 kg , Without stand - width: 74.03 cm - depth: 6.77 cm - height: 43.98 cm - weight: 6.8 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
