Samsung U32D970Q 32" 3840x2160 8ms DVI HDMI DisplayPort USB LED Monitor
Quicklinx: B4RMWS00 Mfr#: LU32D97KQSR/EN
Featuring a 32" UHD screen, this monitor provides nearly four times greater resolution than standard 1920 x 1080 FHD. View content with significantly greater precision and detail. So you can enjoy exceptional viewing clarity, be more productive and maximize efficiency.
  • White balance correction
    Enjoy perfectly corrected white balance for accurate color thanks to advanced H/W calibration technology and white balance correction. The UD970 knows the exact white balance needed and expertly corrects the temperature for a more vivid picture quality.
  • Meticulous pre-calibration process
    Each monitor is individually calibrated at the factory to provide uniform color presentation across the entire screen, even in the corners of the display area, eliminating darker colors appearing around the screen's periphery.
  • Color details and clarity in every shade of gray
    Carefully calibrated with Gamma Curve and Gray Scale Correction ensures images are lifelike, with the correct amount of light, shade and color to express every detail. This correction of Gray Scale and Gamma Curve is crucial to producing high-detail, high-quality work that you will always be proud of.
  • Minimalistic, ergonomic design
    The minimalistic design provides a clean aesthetic, making it a pleasure to work. The ergonomic stand with sophisticated hinge technology allows for versatile height adjustment, tilt, swivel and pivot. So you can fit the monitor to your everyday needs.
  • Dual color mode
    View two different single-color modes in one screen. With Dual Color Mode you can easily view color comparison of two images simultaneously, regardless of the image sources.
Samsung U32D970Q - UD970 Series - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class D
Energy Consumption per Year
131 kWh
Power Consumption (On mode)
90 W
USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
Pixel Pitch
0.1816 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Matte black, titan silver
72.78 cm x 28 cm x 62 cm
13.7 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, RoHS, EMI, FOGRA
3-year warranty
Display Type
Energy Class
Class D
131 kWh
Diagonal Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
Native Resolution
Pixel Pitch
0.1816 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Eco Saving, Lifelike Color, Magic Upscale, Mercury free, Image Size, PIP 2.0, PBP, USB Super-charging, OSD Auto Rotate, AutoPivot sensor, programmable key
72.78 cm x 28 cm x 62 cm - with stand
13.7 kg
5 x USB 3.0 , HDMI , 2 x DisplayPort , DVI-D , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
1 x USB cable , 1 x DVI cable
Power Supply
Internal
90 W
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities, Samsung MultiScreen
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 72.78 cm - depth: 28 cm - height: 62 cm - weight: 13.7 kg , Without stand - width: 72.78 cm - depth: 6.21 cm - height: 42.73 cm - weight: 10.3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 36 months
