Product
Samsung U28H750 28" 3840x2160 1ms HDMI DP LED Monitor
Quicklinx: D7DPWS00 Mfr#: LU28H750UQUXEN
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI
More than 50 in stock
£298.76 ex VAT
£358.51 inc VAT
Blending infinitesimal quantum dots with billions of hues, the UH75 restores images in their true colors, vividly and accurately. Especially with greens and reds refreshingly freed from desaturation, what you see on the screen simply comes alive as if unmediated by a screen. Samsung's Picture-by-Picture capabilities let you connect to two different devices at the same time while still maintaining the original image quality. The Picture-in-Picture feature allows you to do away with the need for a second monitor even when you are multitasking. You can resize the second image and position it anywhere you wish. Slim-bodied with narrow bezels and its sleek back, the UH75 in short is a performance in beauty. Its urbane, modern appeal will seamlessly blend in with any décor of your choice.
Samsung UH75 Series U28H750UQU - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Black, silver
65.37 cm x 24.28 cm x 47.63 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
28"
Viewable Size
27.9"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Black eQualizer, Flicker Free technology, Eye Saver Mode, Factory Calibration Report, Off Timer Plus, Quantum Dot Technology
Black, silver
65.37 cm x 24.28 cm x 47.63 cm - with stand
5.2 kg
DisplayPort , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-1/+20
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
34 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 65.37 cm - depth: 24.28 cm - height: 47.63 cm - weight: 5.2 kg , Without stand - width: 65.37 cm - depth: 9.46 cm - height: 37.6 cm - weight: 4.7 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Samsung U28H750 28 Bundle deal on Samsung U28H750 28" 3840x2160 1ms HDMI DP LED Monitor
£398.52
Diagonal Size: 28in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: 150 - 300
