The Samsung UE590 UHD monitor offers PC viewing, gaming and more, all in stunning Ultra HD picture quality. Superb images that boast a staggering 8 million pixels are delivered at a resolution 4x greater than Full HD. See your 4K content the way it was meant to be seen, with realistic detail that makes you feel like you're really there. Experience a level of clarity in Ultra High Definition.
Expresses the full sRGB color gamut for exact reproduction of digital image colors on screen. With the highest brightness level of 300 cd/m², the picture quality is more vivid and brilliantly clear.
Picture-by-Picture lets you view 2 different input sources on one screen while maintaining the picture quality of the original source. Multitask while you watch a variety of content, thanks to support for even more inputs with Picture-in-Picture 2.0. Resize the second picture to cover up to 25% of the screen and position it anywhere you please, and even control the sound settings with ease.
Discover the detail of stunningly realistic UHD picture quality
The Samsung UE590 UHD monitor offers PC viewing, gaming and more, all in stunning Ultra HD picture quality. Superb images that boast a staggering 8 million pixels are delivered at a resolution 4x greater than Full HD. See your 4K content the way it was meant to be seen, with realistic detail that makes you feel like you're really there. Experience a level of clarity in Ultra High Definition. -
Experience incredibly vibrant color and high brightness level
Expresses the full sRGB color gamut for exact reproduction of digital image colors on screen. With the highest brightness level of 300 cd/m², the picture quality is more vivid and brilliantly clear. -
Powerful multitasking features for maximum productivity
PBP: Picture-by-Picture lets you view 2 different input sources on one screen while maintaining the picture quality of the original source. Multitask while you watch a variety of content, thanks to support for even more inputs with Picture-in-Picture 2.0. Resize the second picture to cover up to 25% of the screen and position it anywhere you please, and even control the sound settings with ease. -
A professional ergonomic monitor for truly professional needs
An ergonomically designed Height Adjustable Stand allows for flexible height adjustment up to 130 mm. Change your monitor perspective from horizontal to vertical with 90° pivot rotation. When the screen pivots, Auto OSD Rotation automatically adjusts the OSD to the screen. Easily and smoothly tilt the screen forward 20° and backwards 5° for comfortable viewing. -
Easy on the eyes for a more comfortable viewing experience
Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button.Flicker Free technology reduces screen flickering for a more comfortable viewing experience. -
Take your entertainment to new heights of immersion and comfort
Dynamically syncs the screen refresh rate with the frame rate of your content to minimize input latency and dramatically reduce image tearing and stutter during gaming. With an upgraded HDMI that supports UHD resolutions at a 60 Hz refresh rate, 4K content plays smoothly without delay, even when connected to AV devices. Instantly adjust your monitor settings for an optimized gaming experience through the on-screen display. Game Mode improves the darkness of the picture so that you can see all the action vividly. See even the fastest on-screen motion clearly without any motion blur, judder or ghosting. -
Maximize your workplace efficiency with a more organized setup
Samsung's UE850 includes several simple but useful features that help to organize your professional workspace and let you focus on your work. VESA 100 x 100 compatibility enables wall mounting, while the built-in power supply means you don't need an additional adaptor. Also the integrated cable holder, conveniently located on the rear of the stand, keeps all your monitor cable connections in place. -
Expand functionality and convenience with advanced connectivity
Triple Interface provides seamless connectivity with your PC and AV equipment with an HDMI port, DisplayPort 1.2, and Mini DisplayPort (also supports Thunderbolt). 4 fast USB connections replace the need for a docking station.
- Samsung U24E850R - UE850 Series - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class C
- Energy Consumption per Year
- 59 kWh
- Power Consumption (On mode)
- 41 W
- USB 3.0 hub
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.13575 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black, titan silver
- 56.1 cm x 26.06 cm x 39.72 cm
- 6.69 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 59 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.13575 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture in picture, MagicBright, picture by picture, MagicRotation, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eye Saver Mode
- 56.1 cm x 26.06 cm x 39.72 cm - with stand
- 6.69 kg
- Headphones , HDMI , DisplayPort , 4 x USB 3.0
Mechanical
- Tilt Angle
- -5/+22
- Rotation Angle
- -1.5/+91.5
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x USB cable
- TUV GS
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 41 W
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56.1 cm - depth: 26.06 cm - height: 39.72 cm - weight: 6.69 kg , Without stand - width: 56.1 cm - depth: 5.93 cm - height: 33.61 cm - weight: 4.21 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
