Samsung U24E850R 24" 3840x2160 4ms HDMI DisplayPort USB 3.0 LED Monitor
Quicklinx: B8MJWS00 Mfr#: LU24E85KRS/EN
The Samsung UE590 UHD monitor offers PC viewing, gaming and more, all in stunning Ultra HD picture quality. Superb images that boast a staggering 8 million pixels are delivered at a resolution 4x greater than Full HD. See your 4K content the way it was meant to be seen, with realistic detail that makes you feel like you're really there. Experience a level of clarity in Ultra High Definition.
Expresses the full sRGB color gamut for exact reproduction of digital image colors on screen. With the highest brightness level of 300 cd/m², the picture quality is more vivid and brilliantly clear.
Picture-by-Picture lets you view 2 different input sources on one screen while maintaining the picture quality of the original source. Multitask while you watch a variety of content, thanks to support for even more inputs with Picture-in-Picture 2.0. Resize the second picture to cover up to 25% of the screen and position it anywhere you please, and even control the sound settings with ease.
  • Discover the detail of stunningly realistic UHD picture quality
  • Experience incredibly vibrant color and high brightness level
  • Powerful multitasking features for maximum productivity
    PBP: Picture-by-Picture lets you view 2 different input sources on one screen while maintaining the picture quality of the original source. Multitask while you watch a variety of content, thanks to support for even more inputs with Picture-in-Picture 2.0. Resize the second picture to cover up to 25% of the screen and position it anywhere you please, and even control the sound settings with ease.
  • A professional ergonomic monitor for truly professional needs
    An ergonomically designed Height Adjustable Stand allows for flexible height adjustment up to 130 mm. Change your monitor perspective from horizontal to vertical with 90° pivot rotation. When the screen pivots, Auto OSD Rotation automatically adjusts the OSD to the screen. Easily and smoothly tilt the screen forward 20° and backwards 5° for comfortable viewing.
  • Easy on the eyes for a more comfortable viewing experience
    Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button.Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
  • Take your entertainment to new heights of immersion and comfort
    Dynamically syncs the screen refresh rate with the frame rate of your content to minimize input latency and dramatically reduce image tearing and stutter during gaming. With an upgraded HDMI that supports UHD resolutions at a 60 Hz refresh rate, 4K content plays smoothly without delay, even when connected to AV devices. Instantly adjust your monitor settings for an optimized gaming experience through the on-screen display. Game Mode improves the darkness of the picture so that you can see all the action vividly. See even the fastest on-screen motion clearly without any motion blur, judder or ghosting.
  • Maximize your workplace efficiency with a more organized setup
    Samsung's UE850 includes several simple but useful features that help to organize your professional workspace and let you focus on your work. VESA 100 x 100 compatibility enables wall mounting, while the built-in power supply means you don't need an additional adaptor. Also the integrated cable holder, conveniently located on the rear of the stand, keeps all your monitor cable connections in place.
  • Expand functionality and convenience with advanced connectivity
    Triple Interface provides seamless connectivity with your PC and AV equipment with an HDMI port, DisplayPort 1.2, and Mini DisplayPort (also supports Thunderbolt). 4 fast USB connections replace the need for a docking station.
Samsung U24E850R - UE850 Series - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
41 W
USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.13575 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
Black, titan silver
56.1 cm x 26.06 cm x 39.72 cm
6.69 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS
3-year warranty
Display Type
Energy Class
Class C
59 kWh
Diagonal Size
24"
Viewable Size
23.5"
Built-in Devices
USB 3.0 hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.13575 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, MagicRotation, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eye Saver Mode
Black, titan silver
56.1 cm x 26.06 cm x 39.72 cm - with stand
6.69 kg
Headphones , HDMI , DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+22
Rotation Angle
-1.5/+91.5
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x USB cable
TUV GS
Power Supply
Internal
Input Voltage
AC 120/230 V
41 W
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.1 cm - depth: 26.06 cm - height: 39.72 cm - weight: 6.69 kg , Without stand - width: 56.1 cm - depth: 5.93 cm - height: 33.61 cm - weight: 4.21 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
