Product
Brand
Samsung U24E850R 24" 3840x2160 4ms HDMI DisplayPort USB 3.0 LED Monitor
Quicklinx: B8MJWS00 Mfr#: LU24E85KRS/EN
The Samsung UE590 UHD monitor offers PC viewing, gaming and more, all in stunning Ultra HD picture quality. Superb images that boast a staggering 8 million pixels are delivered at a resolution 4x greater than Full HD. See your 4K content the way it was meant to be seen, with realistic detail that makes you feel like you're really there. Experience a level of clarity in Ultra High Definition.
Expresses the full sRGB color gamut for exact reproduction of digital image colors on screen. With the highest brightness level of 300 cd/m², the picture quality is more vivid and brilliantly clear.
Picture-by-Picture lets you view 2 different input sources on one screen while maintaining the picture quality of the original source. Multitask while you watch a variety of content, thanks to support for even more inputs with Picture-in-Picture 2.0. Resize the second picture to cover up to 25% of the screen and position it anywhere you please, and even control the sound settings with ease.
Samsung UE850 Series U24E850R - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
41 W
USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.13575 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Black, titan silver
56.1 cm x 26.06 cm x 39.72 cm
6.69 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class C
59 kWh
41 W
Diagonal Size
24"
Viewable Size
23.5"
Built-in Devices
USB 3.0 hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.13575 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, MagicRotation, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eye Saver Mode
Black, titan silver
56.1 cm x 26.06 cm x 39.72 cm - with stand
6.69 kg
Headphones , HDMI , DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+22
Rotation Angle
-1.5/+91.5
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x USB cable
Power Supply
Internal
AC 120/230 V
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.1 cm - depth: 26.06 cm - height: 39.72 cm - weight: 6.69 kg , Without stand - width: 56.1 cm - depth: 5.93 cm - height: 33.61 cm - weight: 4.21 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
