Your basket is empty
Samsung Touch Overlay for 75" LFD with IR Technology - ME75B/ME75C
Quicklinx: 9HNLWS00 Mfr#: CY-TM75LBC/EN
Samsung Touch Overlay turns the display into an interactive board with dual drawing performance and allows for integrators and businesses to quickly add touch capabilities without the need to replace the display. The Touch Overlay seamlessly attaches to the frame of the bezel enabling a fully integrated touch display solution.
Samsung Touch Overlay CY-TM75 - touch overlay - black
Touch overlay
Wired
173.72 cm x 2.55 cm x 101.55 cm
21.1 kg
Multi-Touch
Movement Detection Technology
Infrared
Glass display overlay, 6-point simultaneous touch, aluminium body
Samsung ME75B
Touch overlay
173.72 cm
2.55 cm
101.55 cm
21.1 kg
Input Device
Wired
Infrared
Multi-Touch
Software Included
Magic IWB 2.0 Basic
Samsung ME75B
