Product
Samsung Touch Overlay for 55" LFD with IR Technology - ME55C/ME55B
Quicklinx: 9HNTWS00 Mfr#: CY-TM55LCC/EN
Samsung Touch Overlay turns the display into an interactive board with dual drawing performance and allows for integrators and businesses to quickly add touch capabilities without the need to replace the display. The Touch Overlay seamlessly attaches to the frame of the bezel enabling a fully integrated touch display solution.
  • Transform existing LFDs into interactive touchscreens
    The Touchscreen Overlay Accessory converts a standard LFD into a touchscreen LFD for a more interactive viewing experience. A special treatment on the front of the panel provides a realistic writing experience that is similar to writing on a conventional whiteboard.
  • Add value to an LFD with quick overlay installation
    Samsung overlay accessories offer installation that is designed to be quick and uncomplicated. The installation process enables businesses to upgrade LFDs within minutes, as compared to competitor all-in-one products that require additional steps. Samsung overlay accessories are lighter, slimmer and less expensive than most conventional LFDs that have touchscreen and protective glass features.
Samsung Touch Overlay CY-TM55 - touch overlay
Touch overlay
Wired
126.7 cm x 3.21 cm x 73.57 cm
9.5 kg
Multi-Touch
Movement Detection Technology
Infrared
Glass display overlay, 6-point simultaneous touch, aluminium body
Samsung ME55B, ME55C
Touch overlay
126.7 cm
3.21 cm
73.57 cm
9.5 kg
Input Device
Wired
Infrared
Multi-Touch
Software Included
Magic IWB 2.0 Basic
