Samsung Touch Overlay turns the display into an interactive board with dual drawing performance and allows for integrators and businesses to quickly add touch capabilities without the need to replace the display. The Touch Overlay seamlessly attaches to the frame of the bezel enabling a fully integrated touch display solution.
- Samsung Touch Overlay CY-TD75LDAF - touch overlay
- Touch overlay
- Connectivity Technology
- Wired
- 173.92 cm x 2.96 cm x 101.72 cm
- 19.5 kg
- Multi-Touch
- Movement Detection Technology
- Infrared
- Antiglare surface, glass display overlay, aluminium body, 10-point simultaneous touch
- Designed For
- Samsung DM75D, DM75E, DM75E-BR
- Touch overlay
- 173.92 cm
- 2.96 cm
- 101.72 cm
- 19.5 kg
Input Device
- Wired
- Infrared
- Multi-Touch
- Included Accessories
- Stylus pen
- Designed For
