Samsung SyncMaster 400BX - 40" LCD flat panel display - widescreen - 1080p (FullHD)
Quicklinx: 7WFHWS00 Mfr#: LH40ARPLBC/EN
  • 1080p
Take the hassles out of your communications with a powerful and flexible screen like the 400BX LFD. Featuring an innovative design that allows for quick and easy video walls and built-in speakers for a full multimedia experience, it is the resource you business needs to stand out. Its brilliant picture quality is supported by internal cooling system that ensures you messaging can stand the test of time. So, give your business the right tools and discover the easy way of reaching your audience.
  • Choose The Right View, Landscape Or Portrait
    This Samsung LFD gives you the flexibility to display your image vertically or horizontally-whatever the situation calls for. With a pivot function that rotates the screen 90° degrees and the freedom to display presentations in portrait mode or advertisements in landscape mode, this makes for one versatile monitor.
  • Save money, save space with built-in speakers
    Maximize your impact with a great picture and crisp audio. Your message will be heard loud and clear with built-in speakers. You'll save money when you eliminate the cost of purchasing separate speakers, and you'll save valuable space as well.
  • A cool way to ensure longevity
    Enjoy continuous, reliable operation thanks to a built-in fan control. Housed inside of the LFD, the fan guarantees you can count on it for years to come without worrying about it overheating. You can even control the fan with an easy-to-use on screen display.
  • A video wall that lives up to your standards
    Create the ultimate video wall with Samsung LFDs that cater to your needs. And because this LFD has an embedded video matrix processor, it supports 1 x 1 to 10 x 10 wall formats, allowing you to enjoy total convenience. Best yet, since they need no additional support, the possibilities are almost endless.
  • A great picture that's glare-free
    Whether you have a story to tell or a product to sell, it's important that your image is crystal clear. This Samsung LFD delivers just that-even if your display is located in a brightly-lit environment. It eliminates any reflections that can disrupt your ad's readability, keeping images smooth and visible.
Samsung 400BX 40" LCD flat panel display - Full HD
Diagonal Class
40"
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite
PC Interface
DVI, VGA (HD-15)
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote control
Microsoft Certification
Compatible with Windows 7
Voltage
220 Watt
96.9 cm x 9.1 cm x 58.2 cm
13.8 kg
Environmental Standards
ENERGY STAR Qualified
220 Watt
Diagonal Class
40"
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
Composite
PC Interface
DVI, VGA (HD-15)
96.9 cm
9.1 cm
58.2 cm
13.8 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Dynamic Contrast Ratio
10000:1
Brightness
450 cd/m²
Colour Gamut
72%
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.461 mm
Response Time
8 ms
Max V-Sync Rate
85 Hz
Max H-Sync Rate
81 kHz
Pivot, Anti Retention
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Surround Mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
DVI-D input , VGA / component video input , Serial , Composite video input , Audio line-in
VGA cable
MPR II, TUV, C-Tick, BSMI, GOST, cUL, DDC-2B, EN55022, NEMKO, NOM, SIQ, EN55024, CISPR 22, CCC, EN 60065, IEC 60065, FCC Part 15, PSB, EK, AS/NZS 3548, DDC/CI, IRAM, KCC, VCCI V-3
ENERGY STAR Certified
ENERGY STAR Version
5.0
Power supply - internal
Input Voltage
Power Consumption Stand by / Sleep
1 Watt
Width (Shipping)
105 cm
Depth (Shipping)
20.3 cm
Height (Shipping)
66.7 cm
Weight (Shipping)
15 kg
10 - 80%
