Watch your entertainment come alive with Samsung's 3D glasses. Featuring the fit-over design, which is perfect for users who already wear glasses, these real 3D glasses with their stylish design will be noticeably more comfortable and will deliver an even better 3D experience. And with a battery type for extended viewing, which lasts long hours, you can now sit back in total comfort and enjoy as much 3D TV as you like. It's the 3D experience you've always wanted.
3D comes to life with fit-over glasses
Watch your entertainment come alive with Samsung's 3D glasses. Featuring the fit-over design, which is perfect for users who already wear glasses, these real 3D glasses with their stylish design will be noticeably more comfortable and will deliver an even better 3D experience. And with a battery type for extended viewing, which lasts long hours, you can now sit back in total comfort and enjoy as much 3D TV as you like. It's the 3D experience you've always wanted. -
Bring 3D to life with advanced performance
Settle for nothing less than the absolute best 3D experience. With the advanced 3D effect, which improves LCD shutter speed, the Samsung 3D glasses SSG-5100GB delivers a 3D performance that is simply stunning. Both lenses, right and left, work in perfect harmony and produce images that are true-to-life. Add to this the stable connection, which keeps a safety link to your TV via RF equipment, and you are ready for a world of entertainment.
- Samsung SSG-5100GB - 3D glasses
- Product Type
- 3D glasses - active shutter
- Battery
- CR2025
- Run Time (Up To)
- 150 hours
- 15.1 cm x 16.1 cm x 3.95 cm
- 24 g
- Designed For
- Samsung PN51F8500, PN60F8500, PN64F8500, UE32F6470, UE40F6470, UE40F7080, UE40F8080, UE46F7080, UE46F8080, UE50F6470, UE55F6470, UE55F6500, UE55F7080, UE65F6470, UN40F6400, UN40FH6030, UN46F6400, UN46F6800, UN46FH6030, UN50F6400, UN50F6800, UN55F6800, UN55F7100, UN55F7500, UN55FH6030, UN60F8000
- Product Type
- 3D glasses
- 3D Glasses Technology
- Active shutter
- 15.1 cm
- 16.1 cm
- 3.95 cm
- 24 g
- Form Factor
- CR2025
- Run Time (Up To)
- 150 hours
- Designed For
- Samsung PN43D490, PN51D490, PN51D550, PN51D6500, PN51D7000, PN51D8000, PN51E550, PN51E6500, PN51E8000, PN51F5500, PN51F8500, PN59D550, PN59D6500, PN59D7000, PN59D8000, PN60F5500, PN60F8500, PN64D550, PN64D7000, PN64D8000, PN64F5500, PN64F8500, UE32F6470, UE40F6470, UE40F6500, UE40F7080, UE40F8080, UE46F7080, UE46F8080, UE50F6470, UE55F6470, UE55F6500SD, UE55F7080, UE65F6470, UN40D6400, UN40D6420, UN40D6500, UN40ES6500, UN40F6400, UN40FH6030, UN46D6400, UN46D6420, UN46D6900, UN46D7000, UN46D7900, UN46D8000, UN46ES6500, UN46F6400, UN46F6800, UN46F7100, UN46F7500, UN46F8000, UN46FH6030, UN50ES6500, UN50F6400, UN50F6800, UN55D6400, UN55D6420, UN55D6900, UN55D7000, UN55D7900, UN55D8000, UN55F6400, UN55F6800, UN55F7100, UN55F7500, UN55F8000, UN55FH6030, UN60D6400, UN60D6500, UN60D7000, UN60D8000, UN60ES7500, UN60F6400, UN60F7100, UN60F7500, UN60F8000, UN65ES8000, UN65F6400, UN65F7100, UN65F8000, UN75F6400, UN75F7100, UN75F8000
