Samsung SSG-5100 3D Active Glasses Battery Operated
Quicklinx: 8Y55WS00 Mfr#: SSG-5100GB/XC
Watch your entertainment come alive with Samsung's 3D glasses. Featuring the fit-over design, which is perfect for users who already wear glasses, these real 3D glasses with their stylish design will be noticeably more comfortable and will deliver an even better 3D experience. And with a battery type for extended viewing, which lasts long hours, you can now sit back in total comfort and enjoy as much 3D TV as you like. It's the 3D experience you've always wanted.
  • 3D comes to life with fit-over glasses
  • Bring 3D to life with advanced performance
    Settle for nothing less than the absolute best 3D experience. With the advanced 3D effect, which improves LCD shutter speed, the Samsung 3D glasses SSG-5100GB delivers a 3D performance that is simply stunning. Both lenses, right and left, work in perfect harmony and produce images that are true-to-life. Add to this the stable connection, which keeps a safety link to your TV via RF equipment, and you are ready for a world of entertainment.
Samsung SSG-5100GB - 3D glasses
3D glasses - active shutter
CR2025
Run Time (Up To)
150 hours
15.1 cm x 16.1 cm x 3.95 cm
24 g
Samsung PN51F8500, PN60F8500, PN64F8500, UE32F6470, UE40F6470, UE40F7080, UE40F8080, UE46F7080, UE46F8080, UE50F6470, UE55F6470, UE55F6500, UE55F7080, UE65F6470, UN40F6400, UN40FH6030, UN46F6400, UN46F6800, UN46FH6030, UN50F6400, UN50F6800, UN55F6800, UN55F7100, UN55F7500, UN55FH6030, UN60F8000
3D glasses
3D Glasses Technology
Active shutter
15.1 cm
16.1 cm
3.95 cm
24 g
CR2025
Run Time (Up To)
150 hours
Samsung PN43D490, PN51D490, PN51D550, PN51D6500, PN51D7000, PN51D8000, PN51E550, PN51E6500, PN51E8000, PN51F5500, PN51F8500, PN59D550, PN59D6500, PN59D7000, PN59D8000, PN60F5500, PN60F8500, PN64D550, PN64D7000, PN64D8000, PN64F5500, PN64F8500, UE32F6470, UE40F6470, UE40F6500, UE40F7080, UE40F8080, UE46F7080, UE46F8080, UE50F6470, UE55F6470, UE55F6500SD, UE55F7080, UE65F6470, UN40D6400, UN40D6420, UN40D6500, UN40ES6500, UN40F6400, UN40FH6030, UN46D6400, UN46D6420, UN46D6900, UN46D7000, UN46D7900, UN46D8000, UN46ES6500, UN46F6400, UN46F6800, UN46F7100, UN46F7500, UN46F8000, UN46FH6030, UN50ES6500, UN50F6400, UN50F6800, UN55D6400, UN55D6420, UN55D6900, UN55D7000, UN55D7900, UN55D8000, UN55F6400, UN55F6800, UN55F7100, UN55F7500, UN55F8000, UN55FH6030, UN60D6400, UN60D6500, UN60D7000, UN60D8000, UN60ES7500, UN60F6400, UN60F7100, UN60F7500, UN60F8000, UN65ES8000, UN65F6400, UN65F7100, UN65F8000, UN75F6400, UN75F7100, UN75F8000
