Product
Samsung SSD PM863a SATA 1.9TB SED Hard Drive
Quicklinx: CS5QWS00 Mfr#: MZ7LM1T9HMJP-00005
A leading-edge SSD for mixed workloads
The SATA 2.5-inch PM863a Solid State Drive (SSD) delivers robust performance and lower latency, along with a high level of QoS (Quality of Service) and enhanced reliability under mixed workloads. The PM863a is ideal for CDNs (content delivery networks), streaming or web server applications and cloud services.
V-NAND technology
Samsung V-NAND technology enables the PM863a to provide a wide capacity up to 3.84 TB on the same footprint, as well as deliver better performance, endurance and power efficiency to provide all the essentials for 24/7 data center environments.
Robust performance
The PM863a shows outstanding random read/write speeds up to 97K/24K IOPS. It also delivers a strong IOPS consistency above 99% in random read, as well as superior performance in random write.
Lower TCO without sacrificing performance
The PM863a boasts a better performance-to-power ratio than standard HDD. This high performance and better power efficiency reduce operating costs of data centers. The SATA 2.5-inch PM863a can replace HDD by using the existing infrastructure and is available in wide capacity options up to 3,840 GB, which can save server space.
Increase data security
The PM863a protects data with AES 256-bit hardware-based encryption. This encryption engine secures data without the performance degradation often experienced with software-based encryption.
Enhanced reliability
The PM863a demonstrates a low probability of data corruption. End-to-end protection keeps data consistent along the entire data transfer path and Power Loss Protection safeguards data in the write cache in the event of power failure. The Dynamic Thermal Guard algorithm monitors the temperature of the SSD in order to prevent thermal shutdown.
Technology leader in innovation
Samsung is a leading solution provider that designs and integrates critical components of the Solid State Drive in house. Because Samsung has intimate knowledge of every component and is a leader in V-NAND technology innovation, it can fine-tune each element and create perfect synergy.
Samsung PM863a MZ7LM1T9HMJP - solid state drive - 1920 GB - SATA 6Gb/s
Solid state drive - internal
1920 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
70 mm x 100 mm x 7 mm
60 g
1920 GB
2.5"
SATA 6Gb/s
70 mm
100 mm
7 mm
60 g
Performance
Drive Writes Per Day (DWPD)
0.8
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 480 MBps (write)
4KB Random Read
99000 IOPS
4KB Random Write
18000 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
