The New Samsung SMT-3232A is a 32" monitor with Full HD a native 1920 x 1080 panel resolution optimized for 24/7 CCTV applications. Benefiting from the latest onboard LED panel technology that offers excellent picture quality along with a fast 8ms response time. Performance is enhanced with a high contrast ratio of 5000:1, 178° viewing angle, and Magicinfo player S3 : Local / Network contents player.
- Hanwha Techwin SMT-3232A LCD display
- LCD display
- Recommended Use
- Surveillance system
- Colour Support
- Display Size
- 32"
- Resolution
- 1920 x 1080
- Video Format
- NTSC, PAL
- Supported Video Signals
- Component video, VGA, DVI, HDMI
- High Definition Monitor
- Built-in Speakers
- 1 speaker
- LED backlight, mediaplayer function
- Black
- Voltage Required
- AC 120/230 V
- Power Consumption
- 77 Watt
- LCD display
- 72.14 cm
- 4.99 cm
- 42.03 cm
- 4.8 kg
CCTV
- Equipment Category
- CCTV monitors
- Component video, VGA, DVI, HDMI; NTSC, PAL
- Audio Support
Studio & Field Monitors
- Recommended Use
- Colour Support
- Display Size
- 32"
- Native Resolution
- 1920 x 1080
- Built-in Speakers
- 1 speaker
- Voltage Required
- AC 120/230 V
- Frequency
- 50/60 Hz
- Power Consumption
- 77 Watt
- Black
Terminals
- Terminals
- (1) x VGA input - 15 pin D-Sub (DB-15) , (1) x DVI-D input - 24+5 pin DVI , (1) x HDMI input - 19 pin HDMI Type A , (1) x component video input , (1) x audio line-in - mini-phone stereo 3.5 mm , (1) x remote control bus - RJ-45 , (1) x remote control bus - 9 pin D-Sub (DB-9)
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
