Samsung SMT-3232A 32" LED 1920 x 1080 Black Monitor
Quicklinx: CDM0WS00 Mfr#: SMT-3232A
The New Samsung SMT-3232A is a 32" monitor with Full HD a native 1920 x 1080 panel resolution optimized for 24/7 CCTV applications. Benefiting from the latest onboard LED panel technology that offers excellent picture quality along with a fast 8ms response time. Performance is enhanced with a high contrast ratio of 5000:1, 178° viewing angle, and Magicinfo player S3 : Local / Network contents player.
Hanwha Techwin SMT-3232A LCD display
LCD display
Recommended Use
Surveillance system
Colour Support
Display Size
32"
Resolution
1920 x 1080
Video Format
NTSC, PAL
Supported Video Signals
Component video, VGA, DVI, HDMI
High Definition Monitor
Built-in Speakers
1 speaker
LED backlight, mediaplayer function
AC 120/230 V
Power Consumption
77 Watt
LCD display
72.14 cm
4.99 cm
42.03 cm
4.8 kg
CCTV
Equipment Category
CCTV monitors
Component video, VGA, DVI, HDMI; NTSC, PAL
Audio Support
Studio & Field Monitors
Recommended Use
Surveillance system
Colour Support
Display Size
32"
Native Resolution
1920 x 1080
Built-in Speakers
1 speaker
AC 120/230 V
Frequency
50/60 Hz
Power Consumption
77 Watt
Terminals
Terminals
(1) x VGA input - 15 pin D-Sub (DB-15) , (1) x DVI-D input - 24+5 pin DVI , (1) x HDMI input - 19 pin HDMI Type A , (1) x component video input , (1) x audio line-in - mini-phone stereo 3.5 mm , (1) x remote control bus - RJ-45 , (1) x remote control bus - 9 pin D-Sub (DB-9)
10 - 80% (non-condensing)
