Samsung SmartThings Water Leak Sensor (2018)
Quicklinx: DS2SWS00 Mfr#: GP-U999SJVLCEA
Type: Water leak sensor
Compatible With: Alexa, Google Assistant, SmartThings
More than 50 in stock
£20.00 ex VAT
£24.00 inc VAT
Express delivery Order within the next 11 hours for delivery tomorrow
Know when there’s a water leak in your home.
  • Know when there’s a water leak in your home.
  • Receive alerts when moisture is detected.
  • Set connected devices to turn on or off when moisture is detected.
  • Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. https://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Water Leak Sensor. Receive alerts or set connected devices to turn on or off when moisture is detected. Also monitors temperature.
SmartThings is the easy way to turn your home into a smart home.
  • Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
  • Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
  • Finally, use the Google Assistant, Amazon Alexa, or the SmartThings app to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home.
In the Box
  • SmartThings Water Leak Sensor.
  • Battery
  • Quick-start guide and health and safety guide.
Requirements
  • Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
  • Visit SmartThings.com for specifications, support, and more.
Technical Information
  • Power: 1 x CR2 battery.
  • Communication Protocol: Zigbee.
  • Range: 15-40 meters depending on your home’s construction.
  • Operating Temperature: 0 to 40°C.
  • Dimensions: 58.9 x 41.9 x 20 mm.
  • Weight: 49.9 grams.
  • Color: White.
  • Warranty: One-year limited warranty.
  • Video capability
    Keep an eye on what matters most while you're away. Receive push notifications to live stream what's going on at home, or record video clips 30 seconds before, and for two minutes after a specified event takes place. Download recorded video clips to your smartphone, which are stored for up to 30 days.
  • Simple set-up
    Includes everything you need to get started. No wiring or installation needed: anyone with broadband Internet connection can easily set up their Hub and connect their devices to start easily monitoring and controlling their home from anywhere with the SmartThings smart phone app.
Samsung SmartThings - water leak sensor
Water leak sensor
Functions
Water leak detection
Power Source
Internet of Things (IoT) Platform
SmartThings
Wireless - ZigBee 3.0
White
1-year warranty
5.9 cm x 2 cm x 4.2 cm
Water leak sensor
Functions
Power Source
Wireless - ZigBee
Max Range Indoors
40 m
Android 6.0 (Marshmallow) or later, Apple iOS 11 or later
Platform
SmartThings
White
Battery Required
1 x CR2
Warranty
1-year warranty
5.9 cm
2 cm
4.2 cm
49 g
Compatible With: SmartThings
Brand: Samsung
Price Range Ex VAT: 0 - 50
