Samsung SmartThings Smart Plug 5 Pack
Quicklinx: FTSQWS00 Mfr#: 5XP-GP-WOU019BBDWG
With the Smart Plug you can upgrade your existing lights, electronics and appliances to make them smart. Control your devices remotely, schedule start and stop times or simply track their use from one, easy to use app. Smart living made simple.
  • Take control of your energy use
    See the current and historical energy use of your devices with the Smart Plug and SmartThings App. Then schedule devices to turn on or off at set times and control them remotely.
  • Voice and app control anywhere
    Use the Smart Plug to add a level of control to your home devices, even when you aren't there. Simply use the SmartThings app on your phone or Samsung TV, or your voice using Bixby, Alexa or Google. Interact with devices from home, the office or even while you're on holiday.
  • Stay connected with extended coverage
    Now your plug is the network. Each Smart Plug works as a repeater by expanding and strengthening your home Zigbee network, so your signal stays strong and goes further. Bigger, stronger networks help keep your other Zigbee devices connected, secure and stable.
Samsung SmartThings Smart Plug (2019) - smart plug - ZigBee - white
Smart plug
Functions
Turn electronics on/off
Power Source
Hardwired
Wireless - ZigBee
White
8.6 cm x 7.1 cm x 8.2 cm
Smart plug
Functions
Power Source
Hardwired
Wireless - ZigBee
White
Nominal Voltage
AC 240 V
8.6 cm
7.1 cm
8.2 cm
127 g
