Know when there’s movement in your home.
- Know when there’s movement in your home.
- Receive alerts if there’s unexpected movement.
- Set connected devices to turn on and off as people come and go.
- Adjust the sensor angle with the magnetic ball mount.
- Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. http://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Motion Sensor. Receive alerts if there’s unexpected movement, set connected devices to turn on and off as people come and go, and much more. Also monitors temperature. Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. Connected devices sold separately.
SmartThings is the easy way to turn your home into a smart home.
- Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
- Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
- Finally, use the Google Assistant, Amazon Alexa, or the SmartThings app to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home.
In the Box
- SmartThings Motion Sensor.
- Battery, magnetic ball mount, and wall-mounting pads.
- Quick-start guide and health and safety guide.
Requirements
- Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
- Visit SmartThings.com for specifications, support, and more.
Technical Information
- Power: 1 x CR2 battery.
- Communication Protocol: Zigbee.
- Range: 15-40 meters depending on your home’s construction.
- Operating Temperature: 0 to 40°F.
- Range: Detects motion up to 4.6 meters with a 120° view
- Dimensions: 56.6 x 55.6 x 50.3 mm.
- Weight: 95.3 grams
- Color: White.
- Warranty: One-year limited warranty.
Video capability
Keep an eye on what matters most while you're away. Receive push notifications to live stream what's going on at home, or record video clips 30 seconds before, and for two minutes after a specified event takes place. Download recorded video clips to your smartphone, which are stored for up to 30 days. -
Simple set-up
Includes everything you need to get started. No wiring or instalation needed: anyone with broadband Internet connexion can easily set up their Hub and connect their devices to start easily monitoring and controlling their home from anywhere with the SmartThings smart phone app.
- Samsung SmartThings - motion sensor - ZigBee 3.0 - white
- Product Type
- Motion sensor
- Functions
- Motion detection
- Power Source
- Battery
- Internet of Things (IoT) Platform
- SmartThings
- Connectivity
- Wireless - ZigBee 3.0
- White
- 1-year warranty
- 5.66 cm x 5.02 cm x 5.57 cm
- Product Type
- Motion sensor
- Functions
- Motion detection
- Power Source
- Battery
- Connectivity Technology
- Wireless - ZigBee
- Max Range Indoors
- 40 m
- OS Required
- Android 6.0 (Marshmallow) or later, Apple iOS 11 or later
- Internet of Things (IoT) Compatible
- Platform
- SmartThings
Motion Sensor
- Detection Range
- 4.6 m
- Form Factor
- CR2
- Battery Included
- Required Qty
- 1
- Included Accessories
- Adhesive strips, magnetic wall mount
- White
- Warranty
- 1-year warranty
- 5.66 cm
- 5.02 cm
- 5.57 cm
- 95 g
- 0 °C
- 40 °C
