Samsung SmartCam PT Full HD Wi-Fi Pan/Tilt Home Camera
Quicklinx: C6WTWS00 Mfr#: SNH-V6410PN/UK
  • microSDHC Card
  • microSD Card
Compact Pan & Tilt monitoring camera - giving you peace of mind
The new Samsung SmartCam PT is ideal for home security and peace of mind when you leave the property or go travelling. You cannot always be at home but with the SmartCam PT it provides reassurance that hopefully all is okay in the home by providing live video HD recording. Unexpected events in the home can be notified to you via your Smartphone or web viewer enabling monitoring anytime and anywhere.
Videos and images can be saved onto micro SD cards up to 128GB and stored recordings can be a big help as evidence if something has occurred whilst out. Intrusion on a dark night will also not be missed at the zones you select because it has night vision up to 5 meters allowing clear image monitoring and capturing.
High resolution video
2M (Full HD) helps you to monitor a clearer and brighter video.
Camera Pan/Tilt
You can move the camera to a desired direction (up, down, left or right) to monitor a wider area.
Privacy mode
For privacy protection, you can turn off the camera at a desired time automatically.
Auto tracking
The camera tracks a moving person or object for monitoring.
Backlight correction
The WDR (wide dynamic range) function can brighten up a dark object which has been affected by the backlight.
Motion zone detection
If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. (max three areas can be set)
SmartCam for Baby Monitoring
Parents always want to be with their children but sometimes leaving is inevitable.
Use the SmartCam and you can always be there with them.
Be present with your family always. Whenever you can access the Internet, you can monitor your children on a PC, Mac, iPhone/Android smartphone, or on a tablet computer remotely at anytime. High-quality video and two-way audio communication allow you to keep bonded to your adorables.
This camera follows what other cameras miss
With Auto Tracking this camera will follow moving objects and capture the action.
  • Watch what matters most
    This camera will capture amazing images. The SNH-V6410 has night vision capability which ensures it will continue to capture high-quality images in low-light conditions.
  • Stay connected
    You cannot always be at home and so peace of mind comes with knowing you can have a two-way conversation within anyone in close proximity to SNH-V6410 via a built-in microphone.
Hanwha Techwin SmartCam SNH-V6410PN - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
8.5 cm x 8.5 cm x 8.4 cm
155 g
Black, dark grey
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3" - 3 MP
Minimum Illumination
0.3 lux - colour , 0 lux - B&W
Focal Length Control
Fixed focal
Focal Length
4 mm
Panning Range (degree)
360
Tilting Range (degree)
155
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Digital noise reduction, progressive scanning, image mirror, Wide Dynamic Range (WDR), Motion Detection Technology, Privacy mode, auto white balance
Environmental Parameters (operating)
0 °C - 40 °C; 0 - 90% relative humidity
Audio Support
Wireless
8.5 cm
8.5 cm
8.4 cm
155 g
United Kingdom
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
4
Infrared LEDs
Infrared Distance
5 m
Digital Video Capture Resolution
1280 x 720, 1920 x 1080, 640 x 360
Frame Rate (max)
Image Sensor
3 MP CMOS 1/3"
Effective Pixels
1944 x 1092
Lens Construction
Fixed focal
Focal Length
4 mm
Horizontal Field of View (degree)
80.9
Vertical Field of View (degree)
43.4
Panning
Range (degree)
360
Tilting
Range (degree)
155
Network Interface
Network Protocols
DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, SSL
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Black, dark grey
Power Requirements
DC 5 V - 2 A
Relative Humidity (operating)
0 - 90%
Resources
The following resources are available for the Samsung SmartCam PT Full HD Wi-Fi Pan/Tilt Home Camera
