Samsung SmartCam HD Plus 1080p Full HD Wi-fi Camera
Quicklinx: CYKPWS00 Mfr#: SNH-V6414BN/UK
Marketing description is not available.
  • 1080p Full HD video
    The SmartCam delivers a powerful viewing experience. The large 1/3.0-inch CMOS sensor allows maximum light through the lens - producing vivid colors, brighter video and stunning detail. The SmartCam also supports up to five multiple viewing streams, meaning both you and your partner can check in on the house at the same time.
  • Two-way talk
    This feature allows you hear what's going on around the camera and reply through your smartphone, no matter where you are. It's possible to soothe your child if they wake up momentarily, encourage your pet to eat from a scheduled feeder, or give your guest a quick walkthrough of where that kitchen set is.
  • Motion and Audio Detection
    Never miss a moment at your house - be alerted through instant push notifications when your dog goes into the kitchen or when your children get home from after-school activities. The Advanced Motion and Audio Detection system recognizes that things like swaying shades, falling leaves and rain are not key events. You will only be notified of true motion events such as someone entering the room or loud incidents such as a window breaking.
  • Motion zone select
    You can specify the areas of your home you want to be alerted to of any activity. If you know that your kids are going to be running through the house, but want to be alerted if anyone approaches from the doorways or windows of your home, simply draw a box around those regions of your screen and the camera will alert you of any activity in those areas. The SmartCam lets you select up to three motion zones in its field of view.
  • Email and mobile notification
    Enjoy peace of mind during your vacation getaway! The SmartCam camera has you covered should the camera detect any motion in its zone of view or sound. The camera will instantly send you push and e-mail notifications allowing you to monitor the occurrence in real time. Best of all, you don't have to waste time watching hours of video. You can set the SmartCam to record up to 30 seconds of footage from detected events should you require the need for later review.
  • True day and night
    The SmartCam camera has you covered at all time by providing accurate, vibrant colors during the day and an advanced IR Cut Filter for night vision. Even in total darkness, the camera delivers clear video up to 32 feet.
  • Samsung Light Enhancer
    The Samsung Light Enhancer technology allows the SmartCam to emit better colored images in low light conditions. The SmartCam illuminates the dark areas in its field of vision while maintaining the quality of the brighter areas at the same time, allowing you to determine who the late night food bandit is.
  • Wide dynamic range
    The SmartCam has you covered if there's a bright light behind your subjects in the camera's field of view. With the Samsung WDR technology, you will clearly see the bright smile on your child's face as she takes her baby steps towards grandma.
  • Ultra-wide angle
    Get the whole picture with the 130° ultra-wide angle lens. The SmartCam gives you a larger view than ever before. Find out which neighbor's kid that is in the corner of the playroom or find out exactly how large that spill in the kitchen is.
Hanwha Techwin SmartCam HD Plus SNH-V6414BN - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6.5 cm x 6.5 cm x 3.65 cm
137 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.3 lux - colour , 0 lux - B&W
Focal Length Control
Fixed focal
Focal Length
2.8 mm
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Progressive scanning, image flip, image mirror, Wide Dynamic Range (WDR), 2D Noise Reduction Technology, Motion Detection Technology, Lens Distortion Correction, digital PTZ function, 3D Noise Filtering, High Dynamic Range (HDR), Audio Detection, auto white balance, Motion Zone Select
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% relative humidity
Audio Support
Wireless
6.5 cm
6.5 cm
3.65 cm
137 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
4
Infrared LEDs
Infrared Distance
10 m
Digital Video Capture Resolution
1280 x 720, 1920 x 1080, 640 x 360
Frame Rate (max)
Image Sensor
CMOS 1/3"
Effective Pixels
1944 x 1092
Lens Construction
Fixed focal
Focal Length
2.8 mm
Network Interface
Network Protocols
DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, SSL
Supported Memory Cards
SDXC Memory Card
Power Requirements
DC 5 V - 2 A
Power adapter
Relative Humidity (operating)
20 - 80%
