Product
Samsung SmartCam HD Plus 1080p Full HD Wi-fi Camera
Quicklinx: CYKPWS00 Mfr#: SNH-V6414BN/UK
Marketing description is not available.
Samsung SmartCam HD Plus SNH-V6414BN - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6.5 cm x 6.5 cm x 3.65 cm
137 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.3 lux - colour , 0 lux - B&W
Focal Length Control
Fixed focal
Focal Length
2.8 mm
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Progressive scanning, image flip, image mirror, Wide Dynamic Range (WDR), 2D Noise Reduction Technology, Motion Detection Technology, Lens Distortion Correction, digital PTZ function, 3D Noise Filtering, High Dynamic Range (HDR), Audio Detection, auto white balance, Motion Zone Select
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% relative humidity
Audio Support
Wireless
6.5 cm
6.5 cm
3.65 cm
137 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
4
Infrared LEDs
Infrared Distance
10 m
Digital Video Capture Resolution
1280 x 720, 1920 x 1080, 640 x 360
Frame Rate
Image Sensor
CMOS 1/3"
Effective Pixels
1944 x 1092
Lens Construction
Fixed focal
Focal Length
2.8 mm
Network Interface
Network Protocols
DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, SSL
Supported Memory Cards
SDXC Memory Card
Power Requirements
DC 5 V - 2 A
Power adapter
Relative Humidity (operating)
20 - 80%
