Simple, Smart, Secure SmartCam outdoor helps you look after 24/7 - 1080p Full HD resolution - Weather-resistant housing (outdoor) - Easy installation with PoE adapter - 130° Ultra-wide angle lens - Night vision to 15m(50ft) - Versatile for indoor, outdoor (optional accessory kit for indoor)
- 1080p Full HD Streaming Video
- Outdoor Ready (Weather-Resistant)
- Motion Zone Select
- True Day and Night
Box Contains
- Camera
- PoE Power adapter with plug
- LAN cable(10m/33 ft)
- Screws
- 3 wall anchors
- QIG
- General Public License
- Hanwha Techwin SmartCam SNH-V6430BNH - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: built-in microphone
- 7.8 cm x 7.8 cm x 7.11 cm
- 271 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 0.3 lux - colour , 0 lux - B&W
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- IEEE 802.11b, Ethernet 10Base-T, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac
- Cables Included
- 1 - network cable - external - 10 m
- Voltage
- PoE Class 3
- Progressive scanning, image flip, image mirror, Wide Dynamic Range (WDR), 2D Noise Reduction Technology, Motion Detection Technology, Lens Distortion Correction, 3D Noise Filtering, High Dynamic Range (HDR), Audio Detection, auto white balance, Motion Zone Select
- Environmental Parameters (operating)
- -30 °C - 40 °C; 0 - 90% relative humidity
- Audio Support
- Wired, wireless
- 7.8 cm
- 7.8 cm
- 7.11 cm
- 271 g
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 10
- Infrared LEDs
- Infrared Distance
- 15 m
- Digital Video Capture Resolution
- 1280 x 720, 1920 x 1080, 640 x 360
Image Sensor
- CMOS 1/3"
- Effective Pixels
- 1944 x 1092
Lens Construction
- Fixed focal
- Focal Length
- 2.8 mm
- Network Interface
- Network Protocols
- DHCP, DNS, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, SSL
- Ports
- LAN/power - RJ-45
- Supported Memory Cards
- SDXC Memory Card
- Included Accessories
- PoE adapter
- Cables Included
- 1 x network cable - external - 10 m
- White
- Power Requirements
- PoE Class 3
- Power Device
- 6.7 Watt
- -30 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 90%
